Question about HP Photosmart C6280 Printer
Magenta and pink don't print color well, have lines in it and are not the color they should be, HP Photosmart C6280 All-In-One printer. Issues with indivial print heads, cartridges are full, color is not working well, faded, lines and odd color.
    Scholar:
  • 104 Answers
Is your other color heads are working fine? Have you tried doing the printhead cleaning process. While giving print, just click properties in the page. Go to settings and you can continue with the software wise cleaning process. To do it manually, just visit this link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00491286&lc=en&cc=us&product=1101938&dlc=
Posted on Aug 02, 2010
I just installed new printer cart light magenta & magenta the self diagnostic shows them as loaded and 100 %. The print quality pattern does not print any color for either of them? No error codes?? I have...
printers will only print black and white unless you change the print settings to be color
before you go to print find the printer settings or options and make the default setting color
that way it will print exactly what is sent from the computer to the printer
Feb 07, 2016 | HP Photosmart C6200 C6280 Inkjet...
My HP Photosmart c7280 will not print pink or magenta. How can I fix this issue?
Sounds very much like you have a clogged printer head you should run the deep clean procedure form the printer dialog. If that does not fix the issue you may need to replace the print head.
Jan 28, 2015 | HP Photosmart C7280 All-in-One Printer
HP C6280 won't print red color
1> Please check it color setting. Go to Control panel and printer option choose and right click go to printer property and color section check it only other color setting or not, better default setting and save it.
2> Printer cartridge removed and clean soft hand and proper connect again.
3> Have you printer driver then old driver removed and again reinstalled printer software.
4> Installation before removed infected virus in PC.
Thanks,
HP Printer Support
Jun 23, 2014 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart C6280 printer
new ink the clean as a goo guess
Oct 23, 2017 | HP Photosmart C6280 Printer
Printer says it is fine, but the Magenta is not printing, so I cannot get the correct colors. I have tried cleaning and running the different Tests. Anything else I can do? On the Extended self Test...
Hi, is your magenta cartridge new? if it is new there are some factory defects concerning cartridges but this can be solve, you can go back to the store and let them check the defects of the cartridge or you can go to the nearest hp service center in your area to have a faster transaction.
Jan 04, 2011 | HP Photosmart C7250 All-In-One Thermal...
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
Hp c6280 not printing magenta
magenta colour is empty in your printer.
Feb 26, 2010 | HP Photosmart C6280 Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
Aug 19, 2008 | HP Photosmart C6280 Printer
HP Photosmart C6280 Printer Logo
612 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
