Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Detergent is left in the dispenser cup. Dishes are not clean after going through a complete cycle.
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Please post back for any further assistance.
Daniel
Posted on Aug 02, 2010
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
The dishes are not getting cleaned completely also I have notice some soap left at the end of the cycle.I tried to remove the bottom spin blade and top.Looks like it is too tight.Is it attached with...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 10, 2011 | Maytag MDB7100AWB Dishwasher
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Powder detergent does not dispense into the dishwasher during wash cycle. The powder gets wet and stay in the dispenser and then when the drying cycle comes on it dries the powder and it becomes hard in...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 09, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Detergent dispenser door will not open during the cleaning cycle. Dishes are not being cleaned.
heatman101
Sep 24, 2010 | Frigidaire 24 in. FDB636GF Built-in...
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    LG Dishwasher model LD-1415M. Detergent compartment not opening during washing cycle. Any ideas? Cheers. Joe
    First off, clean the detergent dispenser as best you can using white vinegar.. make sure you get any and all left over soap deposits off the cup and edges of it then,... try cycling the dishwasher without any dishes on the hottest setting and after it is about ten minutes into the cycle.. pause it and add two cups of white vinegar inside the dishwasher.. That should remove most , if not all left over deposits from the system. See if that frees up the dispenser .. Make sure the drain filter is has been cleaned thoroughly prior to running this process.. Hope this helps...
    Sep 14, 2008 | LG Dishwashers
    Detergent trouble
    hi there,
    sounds like the detergent dispenser is not working properly.
    are the rest of your dishes clean? in other words, is there any food residue on them?
    check the dispenser and make sure that there is nothing visibly wrong with it.
    if the problem still persists, replace the dispenser.
    Mar 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    GE 24 in. GSD6660GSS Built-in Dishwasher Logo
    236 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
