Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
Trickle leak refill 1-2 minutes city water 40 PSI
Is the flapper valve/seal leak [4 years old] in the 2 piece common?
  • 33 Answers
The flapper valve is a common piece to obtain and easy enough to replace..
Posted on Aug 02, 2010
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Jun 19, 2011 | Jacuzzi Home
I have installed a Fluidmaster 403 G fill valve, flapper and tank lever to the water tank in my toilet. The tank fills OK but after several minutes the water in the tank has drained out I can not see...
if no leaks in tank. push down on flapper when it fills up. if water stops draining then it is the seal under flapper that is bad. you can lift up flapper and put patrolium jelly on bottom of flapper. this may just seal it. or it needs a certain type of flapper.
Dec 26, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I cannots top leaking. The toilet is full with water but from time to time it opens the walve to get more water in.
When a fill valve opens up from time to time to let more water in it is because the rubber flapper is not sealing properly and is allowing water to slowly seep out.
Toto Caryles have a 5 year parts warranty so keep this in mind if ti applies. If replacing the flapper doesn't solve the seepage problem then the flush valve (the white assembly the flapper connects to) may have to be replaced.
Be sure to install the new flapper at the exact chain length as the one you removed.
Aug 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
May 08, 2010 | American Standard 2004.014 - Champion...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
119 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
