Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Kenmore Elite 17680 gas grill needs a new burner. I purchased the burner, but do not know how to install it. Can this be done as "do it yourself" or does it require a serviceman?
  • Anonymous May 02, 2009
    need new burners installed
  • 4 Answers
I had a local barbeque grill retailer ( a fireplace and barbeque store which did repairs) install a new one for me. I didn't want to mess with the venturi tubes and the exact length of the openings so it would work. I am glad I did as it works perfectly.
Posted on Jun 19, 2008
I have a weber s 620 made for propane but it was converted to natural gas. i had to replace the manifold and it is made for a propane so the grill is not getting hot what can i do?
You need have the orifices that match the fuel you're using - either propane or NatGas. Once you have the correct orifices installed, you should get the proper fuel flow. The propane is at a higher pressure, so the orifice for it is smaller than the ones needed for the lower pressure NatGas. Contact Weber for the kit needed for your model grill.
May 21, 2014 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a Kenmore model 141.16681 and gas now leaks at the regulator valve
check regulator to see that the rubber seal in the tank coupling
is still good if this has perished or fallen out this maybe the cause of
gas at this point.
best purchase a new regulator if it seems faulty, this part is your life saver, and after 8 years good service could well need replacement.
I hope this was useful.
Sep 01, 2012 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Need new burners what is part number and where do I find them
Mine all fell apart too. I went to Walmart garden center and found some one size fits all burners. They go in real easy and are made well. The burner is like a trombone, it slides so it fits many different sizes. The burners are $10 apiece and well worth the money. These will probably never need to be replaced.
Jun 30, 2010 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Weak flames - no pressure
make sure valve is open on the tank all the way
May 01, 2010 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Need a Manual for Turbo STS Elite 4 burner BBQ - HELP!
if you havent already done it call bbq galore 214 696 0030
Sep 08, 2008 | Barbeques Galore Turbo Elite 4-Burner with...
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Elite Grill will not start
The gas regulator that attaches to the tank may be bad.
May 18, 2007 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
360 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
