Question about Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum
I've cleaned a few areas and now the blue nozzle part with the dirt needs to be emptied. I do not have an instruction manual and can't figure out how to open or detach the blue nozzle part to empty it & clean it out.
    Problem Solver:
  • 5 Answers
Release the handle under by the front wheels. It will then pull out. Once you pull it out,on the frame there is a diagram showing out it comes apart.
Posted on Aug 15, 2010
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
    Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
    Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
    Check hose, wands, and power nozzle for blockages.
    Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
    The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
    Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
    If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
    Manual:
    http://www.hoover.com/pdfs/manuals/S3865.pdf
    Thank you for providing the brand and model info. It helps a lot.
    Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
    How do you change the belt of the m5088520?
    Hi There,
    Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
    Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
    screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
    Lift nozzle guard off. Slide belt off motor shaft
    (Diagram 2).
    Lift and remove brushroll (Diagram 3). Dispose of old belt.
    TO REPLACE BELT
    1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
    2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
    orientation (Diagram 3a inset)
    IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
    3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
    I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
    Thanks so much.
    Dirt Devil M088520 Featherlite Vacuum Cleaner
    Owners Manual
    Chris Jones
    GoVacuum.com
    May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
    Having trouble shampooing
    I found this on a website. Hope it helps others...
    by Mainelyvacs in: Kirby
    • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
      So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
    • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
    • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
    • Don’t reuse last year’s leftover mixture, it’s probably no good.
    • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
    • Don’t use shampoo that’s seen extreme temperatures.
    • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
    • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
    Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
    How do you chabge the belt in the dirt devil ultra swivel?
    Attached is a copy of the link for the manual. I have included the steps here, but the manual has drawings on page 10 of the manual, it will tell you how to change the belt. You will need a phillips screwdriver.
    1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat end face up. To remove nozzle guard, use Phillips or Flat head screwdriver to remove the 5 screws. Arrows on diagram shows locations of screws.
    2. Lift nozzle gueard off.
    3. Be sure belt is off motor shaft. Lift and remove brushroll. Dispose of old belt.
    4. To Replace belt, Slide belt onto motorshaft
    6. With new belt in place, pull end slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is prperly aligned.
    7. Reattach nozzle guard
    8. Secure by aligning the 3 tabs in the base slots. Replace all 5 screws to secure nozzle guard.
    http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=23331
    Please rate this solution
    Jul 31, 2008 | Dirt Devil Vacuums
    How to clean the dirt cup
    http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=19813&thid=573199
    Posted by Deneece on May 05, 2008
    How do you clean the "bagless dirt cup" for my Oreck Cordfree Electrik Broom? I do not have an instruction manual since it was given to me.
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
    The best way to clean a dirt cup is to wash it with soap and water and dry it thoroughly so that there is not water or moisture, do NOT however get the filter wet because it will lose filtration and the best way to clean the filter is to brush off the dirt, wipe off the dirt on the filter, or replace the filter id dust and dirt are getting through, other wise wash the cup only with soap and water. Also contact your local vac dealer or Oreck Store in your area or the Oreck factory @ the number listed below t get a new owner’s manual. So feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.oreck.com Customer Service
    Customer Service Hours:
    Monday - Friday
    7am - 7pm Central Time
    Saturday
    8am - 4:30pm Central Time
    Sunday
    Don – The Vac Man
    Go Ahead. Use Us.
    May 05, 2008 | Oreck ElectrikBroom AV-701B Handheld...
    Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum Logo
    212 people viewed this question
    Top Sharper Image Vacuums Experts
    Marvin
    Marvin
    Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
