Question about RCA D52W19 52" Rear Projection Television
My rca 52 inch rear projection tv looks like i am watching a 3d movie without the glasses
We today are having the same problem dont know whts going on here
Posted on Aug 09, 2010
    Genius:
  • 1,030 Answers
CHECK out the aricle fl231 fuse http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_inicle fl231 fuse poroblem.
  • Willie Howell Aug 09, 2010
    the article under tips and tricks section
4 Suggested Answers
hotratchet
  • 952 Answers
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Posted on Jun 19, 2009
SOURCE: RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Posted on Sep 23, 2009
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Posted on Nov 07, 2009
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
My tv looks like it is in 3D without 3D glasses, there are also some wavy color lines at the top of the screen
Most likely cause is FL231 and DL231 having failed. You can get the repair kit called ITC222 & ITC222A convergence repair kit from www.tvrepairworld.com which has the components and also includes the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
My rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Jul 14, 2009 | Televison & Video
My rca color is off it looks like a 3D movie without the glasses? suggestions
your TV needs realignment.  This is adjusting the red, blue and green lenses in the TV.  This is called "convergence".  On some rear projection TV's this is covered in the owners manual.  It usually consists of a test pattern on the screen and a screwdriver alignment to make all the colors overlap one another.  TV's generally go out of convergence by either being bumped or moved.  Hope this helps.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Jun 17, 2009 | RCA D52W19 52" Rear Projection Television
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Looks like watching 3D movie(colors) and rounded
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
