Question about Arris DCT6200 DTV Receiver
My DCT6200 cable box keeps shutting itself off and then turning back on. I have already tried resetting it by unplugging, but that has done nothing. Even after I have turned off the power and left it plugged in, it will shut itself off and on. I have tried different outlets, but other devices work fine so I know its not a power flow issue in the outlet. What do I do?
  • 10 Answers
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
Posted on Aug 18, 2010
How can i get my olevia to turn on it keeps saying no signal. had a storm and it went out
Do you know for sure if the cable box is out sometimes you have to reset the box . usually if you unplug the box for a couple of minutes it will reboot that may do it or try rebooting both at the same time when power is off it really isn't as the units keep current available for instant on that's why its a good idea to unplug most of your appliances when going away. check out the rebooting that should do it
May 21, 2014 | Olevia LT42HVi 42 in. LCD Television
Aig No siginal
Hi THERE,
I WOULD LIKE TO KNOW THE MODEL# AND THE MAKER OF YOUR UNIT..
HAVE YOU TRY TO WATCH ON THE TV IN THE VIDEO MODE?
KEEP ME UPDATED ON HERE.
Sep 30, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
My Motorola DCT6200 Flashing Hunt & a series of F's & Numbers.
motrola 6200 fllashing hunt and when i reset i get E609, according to customer service that provided me with this box, they say the box is diffective and that something is wrong internaly, i'm a cable technician myself and after every test known to us my cable is new, minimum resitance im getteing great levels to my box. i have to beleve custumer service at this point and swaped the box, softboot(unplug power) and hardboot(unplug power while holding down power+select and while still holding the two buttons plug in power and wait till the front of the disply to blink 0000 usualy takes 5seconds after you plug it in, once blinking 0000 release buttons.) after a hardboot you need to call the service provider to re-initialise the box, make sure its not just a zap,(re-initialising means removing the serial number from the account and re-entering it just like the first time its installed) if this does'nt fix it, you need to change it, if it does great. if not you need another box. 90% of the problems issued on motorola 6200,6208,3416 boxes a hard boot will fix, note pvr's and dualtunners will loose saved movies and shows on the harddrive when hardbooted. this will also work in desired conditions, meaning your cable is rg6 cable. not damaged or bent severely, no store splitters, you need a splitter made for digital equipment, meaning there is a electonic board inside, cheap splitters are just sauded together and the communication is not well transfered.. if there is no reason for the cable to have suffered any damage, connectors are properly done, and spitters are provided from the cable company. then its your box.
hope this helps everyone that ever experienced this in the future.
Apr 11, 2009 | Arris DCT6200 DTV Receiver
Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Feb 03, 2009 | Arris DCT6200 DTV Receiver
Non HD channels pixellating...sort of....
i have the same box and notice the same problems it is just becaus anolog siginals are crappy and the way the box converts the things causes the problem. nothing can be done. :(
Jan 22, 2009 | Arris DCT6200 DTV Receiver
Cable box showing d1
Try unplugging your unit for at least one minute then plug it back in . It should reset itself . It will take 20-30 minutes for the guide to start repopulating .
Dec 04, 2008 | Arris DCT6200 DTV Receiver
DCT6200 Receiver Resets when looking at guide
Its your cable box.  You are going to have to swap it with another one.
Aug 27, 2008 | Arris DCT6200 DTV Receiver
Reset
using your remote hit replay-list-live tv 3 times each it will shut of reset then hit list & will read 0
Mar 28, 2008 | Arris DCT6200 DTV Receiver
Arris DCT6200 DTV Receiver Logo
1,264 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
