Question about Cameras
Everytime I turn on my Nikon Coolpix camera it says lens error and I do not know why.
  • Cameras Master
  • 4,924 Answers
Something is blocking the lens to get out ..and the camera can not start ..and it displays the error and close...try to see if something or maybe just the usage under poor conditions like rain or sand ..caused the lens not to open proper..sometimes weak batteries can not action-ate the lens gear ..and the error is on also ...
Posted on Aug 02, 2010
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
Posted on Mar 07, 2009
  • 11967 Answers
SOURCE: Nikon Coolpix S210 Digital Camera .Lens Error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 30, 2010
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Posted on Mar 29, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Posted on Apr 23, 2010
Jimsta01
  • 405 Answers
SOURCE: my digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 24, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Lens error
You can send this to manufacture and they will repair it for $50.
Unless you get lucky enough to find parts on ebay, let me know.
Aug 28, 2009 | Nikon COOLPIX L20 Digital Camera
How can i fix a lens error on s610?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 03, 2009 | Nikon Coolpix S210 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
My camera {nikon coolpix l3}
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 24, 2008 | Nikon COOLPIX S200 Digital Camera
Nikon Coolpix s200
I turned the power on and shook the camera on my palm, lens facing down. And out popped the lens!
Feb 29, 2008 | Nikon Cameras
System error
turn it on and off 6 or 7 times while banging on the body beside the lens. worked for me, cameras been out of commission for 3 years ,apparently lenses tend to stick on coolpix cameras
Dec 17, 2006 | Nikon Coolpix SQ Digital Camera
Cameras Logo
88 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
