Question about Brother Office Equipment & Supplies
We have a brother M4318 dot matrix printer which we successfully use tractor fed forms of 30.5cm 3 part paper to print delivery notes. However if we try to print a replacement delivery note using MS Word as the default template the paper will only feed to 28cms, not to the top of the next form. Any ideas on how we can fix this as we have tried adding footers, altering page length, different feeds ie tractor fed, auto select etc, and we print out temporary tickets normally in batches of 200 at a time
2 Suggested Answers
The Machine
  • 788 Answers
SOURCE: Problems with Printing Special Size Forms
First I would print the menu settings by going into menu mode (Shift+Sel keys) then pressing the print key. Then I would reset the printer to defaults by turning it off and turning it back on while holding the Sel+LF keys. Then go back into menu mode and make sure to match the emulation mode, character set, language set, code page, page length, and all the Parallel I/F settings. Then try your print job again. If you problem still exists then it is most likely that your application of driver on the comptuter is sending the extra lind feeds and that the problem is not with the printer.
Posted on Jul 04, 2008
JackHeath
  • 1049 Answers
SOURCE: Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Posted on Mar 22, 2010
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Printer is bleeping for delivery note to be inserted, however, screen says turn paper lever?
I guess you are using tractor fed paper, the type of paper with holes down the side.
The problem you have is that the paper path has been changed on the printer to the single sheet feeder rather than the tractor feed, you will need to change this back again via the control panel, this is done something like this;
  1. Put the printer Offline
  2. Press Setup
  3. Press the button under PaperWay
  4. Change this to Tractor 1
  5. Press SET
If the above steps do not work disconnect the printer from the computer then try again.
For more info see the Dascom web site;
http://www.dascomeurope.com/support2/technical_notes/serial_matrix/T2240/T2240_tn007.htm
And look for the Online Single & Load section
Oct 14, 2009 | Tally Serial Matrix T2030 Printer
Paper size settings
Thanks for your reply,
Here are the things you might want to try:
1. Go to Printers and Faxes in your Control Panel
2. Right click on the white area and select SERVER PROPERTIES
3. From the FORMS tab, check the box that says CREATE A NEW FORM
4. Enter a Form Name
5. Manually input the specific paper size you want.
6. Press OK
7. To verify if you are successful in creating a new form, right click on the icon of your LX and select Printing Preferences
8. Click on the ADVANCE Button
9. Check under PAPER SIZE
That's supposed to be all, however take note that if the newly created paper size is not showing up, its possible that the paper size is not supported.
Hope this will help
Mar 16, 2009 | Epson LX-300+ II Matrix Printer
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
It would seem you posted twice.
Printer setup
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Mac-Compatible Impact Printer???
Okidata works pretty good for 4 part forms. I've worked on dot matrix printers in the past and found that a lot of them jam with that big of a form and eventually burn the motor out a lot faster. Not a problem to handle on an Okidata.
I have yet to find a USB interface for one so that might be a challenge. Apple used to use a round serial interface. You might be able to find a workaround for that using a USB hub. I have a Belkin one at home that carries an Apple serial interface.
Another idea that could work is to use a parallel based print server with a eternet port on it. Then you can run it on a TCP/IP. The only time you need to use a browser is for administration setup on the print server by typing in the TCP/IP address into the browser.
Safari can work in place of Firefox. Make sure the printer server has Mac drivers for it.
Oct 30, 2008 | Office Equipment & Supplies
67 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
