Question about InFocus ScreenPlay 4805 Multimedia Projector
My sp 4805 shows vertical pinstrips once the screen comes on, can this be fixed?
    President:
  • 1,099 Answers
Check on the thin ribbon cables that go from the LCD screen to the PCB were shorting out/making poor contact. For me it was due to the position of the PCB, but in your case the ribbon cables my be coming unglued from the LCD because of heat or age, or both.
Another thing that could be happening is that the controller board is crapping out on you, open up the projector and see if there are any capacitors hit with the capacitor plague or the like.
If it's a really nice projector, then you might be able to find a replacement controller board on eBay.com, they have quite a few. Otherwise with some searching you might also be able to find a replacement LCD panel.
Hope this helps!
Posted on Aug 02, 2010
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Trouble with my BenQ monitor
You have LCD panel failing issue or it is not getting the proper voltage to the panel. Look at the power supply and logic board section first for failed caps (leaking/bulging tops). check ribbon cable between the logic bd and the LCD panel. If it is vertical stripes, the the T-CON board, part of LCD panel, then you will need new panel.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=benq%20&megnev2=fp71g&kategoria=&kat2=all
May 14, 2010 | BenQ FP71G 17" LCD Monitor
White Vertical line in the screen.
Again, this sounds like a light tunnel failure. See my other post about this.
I replaced my light tunnel with square brass tubing I picked up at the hobby shop.
Sep 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Cheers
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Model hps4253x/xaa vertical lines throughout screen
Need more specfic info. Are the lines on all sources? Are the lines as thin as a Pinstripe?. The possible causes are: The Main bd is bad or the P-Logic bd is bad or the Plasma Panel is bad. Have a trained samsung tech troubleshoot the set.
Jul 13, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
96 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
