Question about Hitachi 53UWX10B 53" Rear Projection Television
Green shadows all over the screen
My TV shows 3 or 4 shadows to right, they gradually fade so the last one is very hard to see. It is most prevalent when I see white lettering, then there's a distinct bright green shadow. It is everywhere on the screen. It only happens when the TV is warm.
I've had the convergence problem before that causes a color to go completely haywire, this is not the same. This is much more subtle.
This was also posted elsewhere, but not under the right TV. Apologies.
    Master:
  • 518 Answers
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Geno
Posted on Apr 25, 2008
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Feb 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Durabrand TV picture died. 2 yrs old
hats the shelf life on that tv
Jan 21, 2008 | Durabrand DWT1905 TV
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
268 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
