Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
I have a GE Profile Arctica PTS22LBMARCC , ser # AD309094 , running all the time , don't seem to shut off.
fridgetech
  • 473 Answers
SOURCE: LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Posted on Oct 18, 2007
  • 1122 Answers
SOURCE: GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
Posted on May 29, 2008
SOURCE: GE PRofile Arctica
Got mine fixed!
http://www.fixya.com/support/t867206-ge_profile_pts25lbmarww_power_but_no
Posted on Aug 07, 2008
sawdust46694
  • 398 Answers
SOURCE: GE Profile Arctica freezer door not sealing properly.
Loosen the hinges on top of the door left side, . lift or lower the door till it is level with the top of the unit. now do the other door. now look at the line between both doors, and compare the gap at the top and bottom . adjust once more time if needed. clean the metal and the magnet with windex then put weson oil on a clean towel and wipe all the way around each door.. hope this was helpfull to you.... Sawdust46
Posted on Aug 11, 2009
  • 396 Answers
SOURCE: Food in the freezer on my side-by-side GE Profile
It's hard to understand how the refrigerator compartment would be okay, but the freezer is not. The evaporator coils are normally behind the freezer. The cooled air is moved from here to the freezer and refrigerator by the evaporator fan. Is this the fan you are saying is going on and off? Or the compressor fan underneath the refrigerator.
The necessary conditions for proper cooling are:
1. Compressor is running; 2. Compressor fan is running; and 3. Evaporator fan is running.
Posted on Oct 18, 2009
Testimonial: "Great info and incredibly timely! I'm a new fan. Thank you."
My GE Artica fridge seems to be freezing then defrosting then freezing again. All of the carboard boxed food is caked with ice and the boxes deterioriate and I have tried resetting the freezer temp s
Those refrigerators have a lot of issues so if you can return it I would. But you can check to see if the freezer fan and fan by the compressor are working. They should be running whenever the compressor is running. If they are you'll need a technician to check out the rest.
Nov 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
My GE Artic Profile refridgerator blows warm air on both sides Model number PSS25MGNAWW SER #420869
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 17, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer Thawing
EITHER replace or re adjust the THERMOSTAT TIMER MODULE , HOPE IT HELPS AJ
Jun 13, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
