Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Scotsman DCE33A-1WB Residential Ice Machine Problem
Scotsman DCE33A-1WB bin will not fill. Machine produces ice, but will only fill to about depth of 3-4 inches. Cleaned condenser, but no change in ice level. The cubes the macine produces seem to be fine, however, just doen't produce enough to fill bin. It was working fine until recently.
    Problem Solver:
  • 7 Answers
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
Scotsman ice maker making more water than ice
Check water inlet valve to make sure it is not letting water seep through causing water to overflow water sump tray and dumping into bin. and the machine will not produce much ice.
Oct 19, 2014 | Kitchen Appliances - Others
Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Oct 31, 2012 | Scotsman Refrigerators
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Why is the orange light on , what does the orange light mean?
If the bin is full there is a light that stays on. If it is time for a cleaning, there is a light that stays on until reset.
Jan 15, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
A continuous grinding sound on my Scotsman DCE33A
I would suspect the water pump is making this noise. If it is, there is no repair, you must replace it.
Jul 01, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
1,306 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
