Washer appears to complete cycle, but water will not drain.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to diagnose your problem when your washing machine won’t drain….go through the given articles to have an indeth knowledge regarding your query….
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itwontdrain
http://www.washerhelp.co.uk/diy-repair-help_3.html#cl_q1
http://www.ehow.com/how_4446778_washing-machine-that-wont-drain.html
http://www.ehow.com/how_5030854_fix-machine-not-drain-spin.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
Whirlpool type 111
is the water being drain completely at the end of the cycle if so your problem must be the level sensor this a diaphram sensor that control the water level setting.
Nov 06, 2013 | Washing Machines
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water remaining in washer after completed
any error codes maybe f21,take the bottom panel off, you'll see the pump on the right hand side,use a pair of plyers to unscrew the middle part of pump,if you have a shop vac turn the middle part counter clock wise slowly when water starts coming out vac it up,also put a towel under the pump to catch water,when it's drained unscrew the middle part all the way and take it out and clean out the pump,feel around inside to make sure nothing is stuck in the impeller of the pump, try blowing through the other end of drain line to see if there is a block in it,put it back together and run it,put it on spin drain and make sure water is pumping out the drain line,if not the pump could of been damaged and you need to replace it
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
