Question about Echo 001106 Power Blower Helper Handle Fits Many Models
What is oil to gas mixture for 2 stroke engine model #pb403t?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
If you are using stihl oil then the mix is 50:1
Posted on Aug 02, 2010
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
What fuel does stihl MS 192 T take, 2 or 4 stroke?
these small engines take 2 stroke oil/gas mixture, usually a 50 : 1 ratio, a little heaver on the oil is better than too light. the oil in the gas lubes the internal parts of the engine. if straight gas is introduced into gas tank just remove & replace with 2 stroke mixture. if engine has not been operated with straight gas, no harm will be done.
Apr 26, 2014 | Garden
Tmail.comdoes the gale buccanner outboard run on a mixture of gas and oil or just gas
A Gale Buccaneer 2 stroke of recent manufacture will run a mixture of one part 2 stroke oil to 50 parts gasoline.
The early models use 24 to 1.
Use only good quality 2 stroke oil.
Using a little more oil doesn't hurt.
Jul 09, 2011 | Sport & Outdoor - Others
I need to know the oil gas mixture for a 2000 yamaha pw90. I couldn't find my make and model so I just choose one so please ignor. It wouldn't let me continue without picking one.
If your model is the 90 then it should be a 4 stroke engine you put 10w30 or 10w40 oil in the engine and gas in the tank. Do not mix oil into the gas tank on a 4 stroker you will knacker the engine big time.
If however you have a definite 2 stroke model, you have 2 oil tanks one for the gearbox, and the plastic one under the seat for the engine.
Gearbox tank fill with 10w30 oil the plastic tank under the seat with 2 stroke oil. The 2 stroker mixes the oil and gas so you don't need to.
Jul 04, 2011 | Power Baghira Street Moto Motorcycles
Need to know the gas and oil mixture for a Homelite 2 cycle weed wacker
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
May 22, 2011 | Homelite Garden
Fuel and two stroke mix pls oil type for chain pls
  • Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Mar 20, 2011 | Oregon Cutting Systems Chain Saw Cutting...
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
On the side of my 86 kx 80 2 stroke there is a hole with a pluge on it do i put tranny or motor oil in it and what fuel mixture should i use(would out board oil work
The plug on the side engine casing is for 10w40 motor oil. NEVER use synthetic lubricants or oil with 'special' additives. They can mess up your clutch. The 10w40 motor oil is shared by the gearbox and the engine because they are a single unit.
Use 4 ounces of two stroke engine oil for every gallon of gas. That will give you a 32 to 1 mixture which is the industry standard. If the outboard motor is a 2 stroke (most of them are), the engine oil is the same. Note the difference > Engine oil verses Motor oil. Motor oil in the gearbox, Engine oil in the gas.
Feb 07, 2010 | 2003 kawasaki KX 250
Hi im after the fuel mixture for a 125L husqvarna straight shaft brush cutter.thanks
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I NEED TO KNOW THE GAS OIL MIXTURE FOR A HOMELITE WEED WACKER.MODEL # UT20593C
the basic oil, gas mixture for a 2 stroke engine is 50 to 1
Apr 26, 2009 | Garden
Echo 001106 Power Blower Helper Handle Fits Many Models Logo
117 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
