Question about Haier (HPE09XC6) Air Conditioner
My Haier Air conditioner is leaking a large amount of water into the house.
I just had this problem. I removed the back and it seemed the drainage area was clogged from mold. I cleaned out the mold from one are (in the middle of the unit) and immediately the water started flowing through the draining tube. Getting the back off and on again was pretty easy. There were a bunch of screws but they all seemed to be of the same size. While the leakage problem was happening I wasn't even getting the triangle warning light. I guess the water was blocked high up in the unit and the "empty water" sensor is down toward the bottom.
Posted on Aug 04, 2012
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
22yooper
  • 828 Answers
SOURCE: rv air conditioner leaking
In each of these cases I would check for proper connection of the return air vent to the A/C from below. Static pressure from insufficient return air could cause negative pressure to hold back on condensate drainage. when the unit is shut off the pressure becomes equal allowing water to drain. Also check air filter and clean if found necessary.
Posted on Jul 18, 2008
  • 659 Answers
SOURCE: daikin air conditioner leakin water at a fast rate
You should have access to the condensate drain from the outside. You can use compressed air to unclog the unit. If you can, try accessing the drain from the source outward but be careful, you can blow debris everywhere. Make sure you have something to catch it so it doesn't spray everywhere. If you don't have access to compressed air, you can use a small plumbing snake to work you way up the pipe. Hope this answers your question.
Posted on Mar 20, 2009
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
Water leaking inside the house
The air conditioner should be mounted in such a way that there is a slight tilt outside to direct condensate away from the inside. Your air conditioner may be level or slightly tilted toward the inside. The installation instructions should have made this point clear
Aug 04, 2013 | Haier hwr10xc6 Air Conditioner
Hello, I noticed yesterday that my air Haier ESA408j-l window air conditioner was dripping an excessive amount of water into the window. Most likely due to the high heat and humidity in the area, the air...
Dry it all out and try again . but be very carful and be certain you are not coming in contact with any water when you plug it back in and yes it will take more thatn atowel to keep things dry move it to the window and be certain it is tilted to theout side a little
Jul 19, 2011 | Heating & Cooling
I have a haier hwfo5xc7-l window air conditioner and it leaks water on the inside what is causing this ?
A couple of things can cause this: The drain hole in the condensation pan under the unit on the outside is clogged and/or the outside part of the AC unit is not sloped down at least 1/4". Resolving those two issues should stop the water leakage on the inside of the house.
Hope this helped you troubleshoot and solve the problem..
Jun 26, 2011 | Haier Heating & Cooling
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
My Amana AP095R is leaking copious amounts of water. Please help.
not sure if it is a split or window unit if ti is a split unit it may be that the unit needs servicing and that the main drain pan has backed up depends on where it is leaking it can be the the secondary drain pan at the back of the unit that has two small ports that gets plugged up at times
May 03, 2010 | Amana Haier AP095R Air Conditioner
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Haier (HPE09XC6) Air Conditioner Logo
4,937 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
