Question about Kyocera Mita KM-3035 All-In-One Laser Printer
C2500 problem with keyocera mita 3035 - Kyocera Mita KM-3035 All-In-One Laser Printer
  • 29 Answers
A C2500 Code is as follows (direct from tech manual.)
Paper feed motor problem.
Poor contact in the paper feed motor connector terminals.
Defective paper feed motor rotation control circuit.
Defective drive transmission system.
Solutions:
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable.
Replace the paper feed motor.
Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace
if any.
Most of the time it is the motor if you power the unit down and unplug it. Wait 30 seconds power it back up and it should (key word) bypass the broken cassette. To find out if it is the motor you can switch the motors with cassette 1 and 2 they are the same.
Hope this helps.
Posted on Aug 24, 2010
WHITE LINE THRU PRINT ON KYOCERA MITA KM-3035
clean the LASER glass for that color, if you dont know what that is get a tech out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 22, 2016 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera km 5035 error c2500
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Error c2500
This error code indicates that the paper feed motor has locked up.
Check that no paper is jammed anywhere inside the machine.
This can be reset by powering off the machine.If the error code returns then it would indicate that something is restricting the cycling of the machine and a technician is required to attend.
Aug 05, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Can not print to Kyocer Mita KM-3035 from my computer
Try this PDF from kyocermita.be http://www.kyoceramita.be/content/pool/be/en/printer_multifunctionals/faq/i_need_detailed_information.-cps-80474-files-33494-File.cpsdownload.tmp/KX_Printer_Driver_Guide%20v1%5B1%5D.2.pdf
Aug 25, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera mita 3035 is offline cannt figure out how to get it back online
If you are taking about the printer portion. Just hit the printer button on the left hand side. When the printer options pop up on the touch screen chose the option on the bottom right hand side (the GO key) of the touch screen that should bring it back online.
Hope this helps.
Aug 06, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
I need my scanner hookedup tomy pc on my mita 3035
You must have a Kyocera or Copystar technician set this up for you.
Jul 15, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I NEED ASSITANCE
what's the problem of your machine?
Jun 20, 2009 | Kyocera KM-1505 Copier
Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Apr 03, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
1,624 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
