Question about Blaupunkt Bahamas MP46 CD Player
In my cedia bahmas mp46 is installed i want to attach an aux chord to it but how to take the player out from the unit
Hello if you still want to solve this, This rquires removing the front panel. Thee are 2 screws inside the coin holder underneath the music panel. you wil be able to see them only if you bend down and see it. Remove them and the front centre panel will come out. then the screws that hold the music player will be visible. The you can remove them and slide th music unit out to fix your pod cable.
Posted on Nov 18, 2010
How to turn demo mode off on Blaupunkt MP46 ?
go to settings and then in display find demo and turn it off there.
Apr 24, 2014 | Blaupunkt Bahamas MP46 CD Player
My iPod won't play threw my car speakers
is it turned up all the wayy on the actual ipod ? you need to make sure the stereo is on either "AUX" or "AUDIO IN" if that is all fine, get a new aux chord
Jan 06, 2014 | Apple iPod touch
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
Cannot get rear aux input source to work on pioneer deh-p6800mp. no option in function to able/disable that function. also would like to know the name of the type of plug that is used for front aux. input...
The type of plug on the front aux is a 2.5mm plug similar to what cell phones use. You need a stereo 2.5mm to 3.5mm adapter, then you can run a chord with a 3.5mm jack on both ends to an iPod or some other type of mp3 player.
Dec 14, 2009 | Pioneer DEH-P6800MP CD Player
I have a balupunkt bahamas mp46 car cd stereo. i keep on getting CD error and it wont eject, allow me to put in, play or do anything with any cds at all. i dont think there is one stuck in there either. i...
You need to pull the unit out of the dash and pop the top and manually release the disc. If you don't have the keys for the side tabs (if it's not Iso-mounted) check a local car audio shop. They generally can be very helpful. Hope this helps. If your not sure how, post a comment with the make and model car and I can help you further.
Aug 17, 2009 | Blaupunkt Bahamas MP46 CD Player
Following the passlock procedure on an 05 avalanche soes not work
check the fuse and relay again, make sure that the pcm wire are connect properly, get it reprogramme
Jul 17, 2009 | 1997 Chevrolet Cavalier
Cant adjust sub out and midrange like i used too.
Hello chev_454,
You can adjust the sound settings for bass, middle, treble, and sub out separately for each source, tuner, CD, AUX, etc. The adjustment procedure is on page 26 of the owners manual. If you do not have a manual, you can download a PDF copy here at Crutchfield. They show the Bahamas as a discontinued m,odel but the manual is still in their database.
Hope this helps.
Jun 02, 2009 | Blaupunkt Bahamas MP46 CD Player
Where is the AUX input on this player?
Sorry, but the RCA jacks for Aux input are only available in the back of the player. If possible, you could try to attach RCA jumpers to the jacks without removing the unit, but as I have no idea of the vehicle involved, I can't say if that would be possible. IF you have the "Release" keys, sliding the chassis out should not be a problem. Slide out, attach jumpers, and slide back in after routing the jumper cable(s). (This also assumes the unit was slid in using the standard slide in and lock mounting.)
Hope that isn't all bad news. Good Luck.
Nov 01, 2008 | Panasonic CQ-C7103U CD Player
KENWOOD KDC-MP335
Yes, you can. It took me almost a month and about 70 dollars wasted to lfigure it out though. All you need is the the audio jack. Its a simple chord that runs to your aux jack in the back of your head unit. MAKE SURE YOU HAVE ACTIVATED THE AUXILLARY CONTROLS ON THE CD PLAYER. YOU DO THIS FROM THE MENU SCREEN. The chord cost like five dollars at wal-mart.
Aug 10, 2008 | Kenwood KDC-MP335 CD Player
Blaupunkt Bahamas MP46 CD Player Logo
62 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
