Question about Craftsman Garden
Engine GCV190-AS3A Honda idles too fast. How to
Engine GCV190-AS3A Honda idles too fast. How to adjust idle?
  • 6 Answers
SOURCE: will not drop down from fast idle when first started
It sounds like an automatic choke system. Let it warm up for 5 minutes and then give it gas up to 2000rpm and release.
Posted on Nov 19, 2008
  • 599 Answers
SOURCE: IDLE SPEED
timing adjustment ..or you have a vacuum leak brother
Posted on Nov 21, 2008
panilling9
  • 284 Answers
SOURCE: ryobi cs30 starts fine, but idles way too fast
you need to take your air filter off and look into the throat of the carbruetor to see if the ""Butterfly""
is still intact and working not the choke butterfly its the one closest to the engine that moves with the throttle and be sure it is still there and moves as you move the throttle.... open is horizontal and closed is not quite 90 Degrees. check to see it is tight and in the center if the throat when closed.
you may have to remove the carb. to see it function more clearly
make sure the throttle cable is free and not binding any where and to be sure of its adjustment to allow the throttle to return to the idle position.
lubricate the cable from the trigger to carb. wd 40 is ok.
if all above is ok then find the L on the carb. and ccw it 1/8 turn to ritchen it alittle to help slow the idle down some to a respectable level
Posted on Jul 04, 2009
  • 5 Answers
SOURCE: 2002 Honda Accord V6 check engine light on- local
po505 idle air control if this is the code all hondas do it eventully, small problem easy fix u have 2 choices either remove the idle air control motor and clean the inside of it u will find it's black and the spring inside is stuck clean it with carb cleaner or gum cutter any parts store will have this it's a dirty job it will work for awhile but to replace it is recommended its not expensive for a new one which u can get at any autoparts store autozone,advanced,napa etc. there is only 2 bolts in most cases maybe 3 i doubt it though if u go online t google and type in th eyear make and model and engine size in ur case it's a 3.0 v6 and look for idle air control locations u'll find it to do this job a shop will charge u anywhere from 100.00 for diag to retrive the code plus the part and the labor so about 250.00-375.00 it will only take u honestly maybe 15 minutes to perform only tools needed are a 10 millimeter wrench there is only 1 connector to disconnect and ur done if u do this u will still have the check engine light because u have not cleared it from the computer to do this just disconnect the negative battery terminal (the black one or has a neg sign - don't disconnect the positive side +)for 5 minutes then reconnect and the computer will have reset no more light. good luck it really is that easy
Posted on Oct 10, 2009
agent91
  • 2100 Answers
SOURCE: I have a 1987 Susuki Samurai, 1.3 engine. Cold
Yeah it sounds kinda high. There is no adj except for the idle screw on the throttle, the computer does the rest, if it has one. If not, then you can adjust it some how. If carbureted, check for 2 little screws in the front, and check the choke, If throttle body, then just the idle screw, the idle should be around 1000. Hope this helps.
Posted on Jul 03, 2010
Greetings. I have a eu2000 honda inverter with the following problem. The high generator runs too fast, when the idle is activated, slows down a bit, but does not increase
on the governor control back to the carby , there is a screw that adjusts the spring tension for the governor arm
that screw is the adjustment for engine operating rpm not the idle screw
Dec 05, 2016 | Honda Electrical Supplies
I have a 2007 cbr600rr, and I have noticed lately my bike idles around 1900-2000rpm, normal is around 1400-1500rpm(this is when the bike is warm), also when using the engine for braking it feels a little...
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Idle Issues
How to Adjust the idle on 04 06 cbr600RR
2007 2009 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600RR 2007 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2017 | 2007 Honda CBR 600 RR
Where is the throttle screw(for idle speed), of the carb, in honda activa
That idle adjustment screw you are looking for can be found just below the fast idle cam. Which is connected to a spring-loaded hinge with a throttle cable attached.
Jan 22, 2014 | Motorcycles
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
I have a 1991 honda civic hatch with 1.5 engine idles fast cold and hot and ECU flashes twenty times
Hi Jason, I suggest you take the vehicle and have a diagnostic scan carried out. Doing that will pin point the problem area and take out the guess work. I have known occasions when someone has tried to adjust the throttle butterfly, hoping to reduce the idling speed and by doing that have taken the TPS (Throttle Position Sensor) out of the correct adjustment, causing abnormal idle speed. Regards John
Mar 29, 2012 | 1991 Honda Civic
2007 Honda SCV 100 Lead high idle
7. Faulty automatic choke.
8. Broken throttle return spring.
9. Damaged diaphragm or slide.
10. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
11. Multiple carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://crfsonly.com/forum/viewtopic.php?t=22201
Rincon 680 low idle high idle info
SVC100 LEAD 2003 HONDA SERVICE REPAIR MANUAL Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda SCV100 Owner Manual
Feb 22, 2012 | 2007 Honda SCV 100 Lead
2011 HONDA CRF150R HIGH IDLE
2007 Honda CRF150R at idle
How to Adjust Idle On Dirt Bike Tips and Tricks 1
CRF150R service manual repair 2007 2014 CRF150RB Download Manuals Technical $150
Honda CRF 150RB Owner Manual
Jan 25, 2012 | 2011 Honda CRF150R
2005 Honda Shadow VLX high idle
Hi, Verrnanm and the usual suspects are:
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
10. Multiple carburetors not in sync.
idle screw air fuel mix
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim
Honda VT600C Shadow VLX Service Manual
Honda VT600C Owner Manual
Oct 21, 2017 | 2005 Honda Shadow VLX
Honda 4cycle engine Choke setup
Sounds like you dont have the run linkage hooked up right or not hooked up at all go to Honda repair help they can show you how to hook it up.
Sep 12, 2017 | Craftsman Garden
Honda Accord 1991 idles high then low
)The fact that thge engine idle fluctuates when it is cold indicates that the Fast Idle THermo Valve is out of adjustment.
This valve is located ot the front of the intake manifold on the driver's side just below the accelerator cable. To adjust it, wait until the engine is cold (best to do it first thing in the morning).
Remove the two screws holding the cover on and start the engine. There is a brass needle sticking up through a plastic ring that has two slots in it. With the engine idle fluctuating, use a thin flat blade screwdriver to SLOWLY turn the ring CLOCKWISE
until the idle stabilizes. Once done. put the cover back on withg the two screws and you should be done.
Jun 04, 2008 | 1991 Honda Accord
Garden Logo
210 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
