Question about Samsung NV24 HD Digital Camera
Samsung ES60 not charging the charger just keeps blinking a yellow light and it does not charge at all
  • 906 Answers
Link
Kindly consult this problem to your nearest Samsung Authorized Dealer as the possible problem is with the charger as it does not charge anymore. You can browse above link for Samsung Support Team.
Thank you.
Posted on Aug 02, 2010
Wireless charger not charging phone
Normally blinking means charging and the light will stay/keep ON once it completed charging.
May 15, 2014 | Wireless Solutions Plus Wireless Solutions...
I have new batteries and charger but batteries will not charge
If your battery is totally flat some chargers see this as connecting to a short and will not charge. If the battery has a charge run it down some, my batteries often don't take much of a charge if any. Does the charger light up.Does the charger have any fuses on its out put wiring. Open the charger up, do you see fuses. When the charger is on do you see any blinking lights. If you get a blinking yellow light when hooked to a battery there is something wrong with the battery. Hope this helps
May 26, 2012 | Pride Mobility Products Health & Beauty
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
There is a yellow blinking light on my Black jack
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Apr 22, 2009 | Samsung BlackJack II Smartphone
Light on phone blinks yellow
It's normal and means it's charging.
Mar 05, 2009 | Samsung BlackJack Smartphone
Samsung NV24 HD Digital Camera Logo
542 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
