Question about Black & Decker Garden
I can't get my Black & Decker GL220 strimmer to work. Every time I put the line holder in, it works for 3 seconds then cuts off the line.
4 Suggested Answers
  • 9 Answers
SOURCE: how do I rethread the
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
#1 Taper
  • 1041 Answers
SOURCE: threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Posted on Jun 21, 2009
Replacing strimmer line on trueshopping hmlp4304ni1
Hi, on the side of the black spindle should be two tabs, push these in & the spindle cover should come off in your hands, Inside you will find a dual reel, one length of line needs to be fed in one way & the other the other way, making sure you have enough strimmer line free from either the slots or the hole on the side of the reel put this reel back on the spindle & pop on your black spindle cover, Job done.
Aug 17, 2012 | Garden
Just got a Worx GT151 trimmer. For trimming grass has worked fine. Problem is in edging the sidewalk. I start edging and it takes littleraly 2 seconds to wear the string to half it's length, needing to...
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Jul 04, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
My Black & Decker Reflex Strimmer GL570 does notautomatically feed out the line.
disassemble the string part and clean it,,, it is common for them to get gluped up and not feed. All so make sure you have it wound the right way.
Jun 16, 2011 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Jun 01, 2009 | Black & Decker Garden
Black & decker (older) strimmer.
the only thing I can think of its too heavy of a guage of line I would try a size down and make sure that when you wind it that its a nice and smooth transition in it so that nothing is over lapping and going to prevent it also if its done right and you have done it too tight this will also put too much pressure on the line and allow for it to get jammed inside once its being used because of the pressue from use.
Oct 02, 2008 | Black & Decker String Trimmer Cordless 12"...
How do I rethread the cutting line on a black and decker strimmer reflex plus
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
252 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
