Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Brush 32cc will not stay started. They say at theears retailer that it is the spark arrestor. Need to know how to disassemble to get to tis sparl arrestor.
    President:
  • 3,197 Answers
Check the vent hole in the gas cap. It is common for them to become clogged.
Posted on Oct 05, 2010
Craftsman 32cc/170 mph leaf blower. Why does it die after a few minutes running?
Is this a consistent situation? Starts, runs then dies after a little while?
If so, sounds like carburetor/fuel pump (which is a one way diagraphm) issue.
Take carburetor apart, and also obtain a rebuild kit for it. Clean it well, compressed air through all the jets, replace the parts from the kit and reassemble. Re-install back onto unit.
Also... Replace Spark Plug, fuel filter and clean the spark Arrestor screen at muffler.
May 26, 2015 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
CRAFTSMAN 32CC/2.1CU.IN 4 CYCLE MODEL 358.796121 WAS WORKING STOPPED AND NOE WON'T START
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Jim
Jun 25, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer only works on full choke
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Jim
Jun 20, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Trimmer wont run when i take it off choke
No, it will not. Don't take the fuel mix screws out, it's not necessary.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
Jim
Jun 15, 2009 | Craftsman 25cc Gas Line Trimmer
My 32cc weedwacker starts up fine on full choke, move slowly to 1/2 and it will run strong for a couple seconds and then just shuts off. It does this over and over.
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
Jim
Jun 13, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman blower won't start( 24cc 2-cycle)
You may need to do two more additional things.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
Jim
Jun 12, 2009 | Craftsman 4 Cycle Blower/Vac
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
113 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
