Question about Refrigerators
My mini fridge turns on btu after 30 sec it clicks off then after a few min it will click on then off again
peyton32034
  • 410 Answers
SOURCE: refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Posted on Mar 22, 2009
  • 159 Answers
SOURCE: our fridge makes a clicking noise.
does it still makes cold or not but the noise you are hearing is the compressor clickson going on and cut out. try to change the clickson
Posted on May 16, 2009
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Posted on Aug 26, 2009
hiltonjug
  • 612 Answers
SOURCE: Magic Chef mini fridge stopped working. I hear a
You have either a bad capacitor or a bad compressor. If I were there I would put a part on called a 3 in 1. It's made by Supco. It replaces your relay Overload and start capacitor. If the compressor is good, it will fix your problem. Click on this site and you will see the part I'm talking about. It's very simple to put on. http://www.appliancepartsonline.net/index.php?target=categories&category_id=50 The part number is RCO410
Please rate this solution and good luck!
Posted on Sep 05, 2009
Testimonial: "Very helpful. I'll try it."
SOURCE: Compressor makes a running noice for 30 secs and then clicks
I got the Compressor Overload relay Assembly replaced and the compressor started to work.
Posted on Sep 06, 2009
Testimonial: "worked for me"
Emerson mini Fridge will not cool. Electronics?
Sounds like the compressor starting componets or a capacitor is bad.
Jan 03, 2018 | Emerson Refrigerators
Once the unit ccles off, it will not cycle on. If you turn unit off for 30 secs you hear it click and it comes on again.
try and reset it by turning off supply from switchboard,then turn on again after 10 mins.
Feb 07, 2011 | Heating & Cooling
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Liberty will not turn over
Doesn't that jeep have an on board anti theft system that shuts of power to the startee and the fuel injectors. Im pretty sure it does thats where to start sometimes just turn the key to the on position for 30 sec. To 60 sec then crank the engine if that doesnt work turn off at least 10 sec try again tirn to on position without cranking motor for at least 30 sec then try cranking
Sep 20, 2017 | 2003 Jeep Liberty
After 2 hours of use, the tiller will only run long enough to spin around once or twice then stops. The reset button has been clicked. What did I do?
check your owners manual for the duty cycle rating. If it is75% , it can run for 45 mi. and needs to cool for 15 min. before using again. if it is 50% its 30 min. & 30 min.
Aug 16, 2009 | Mantis Electric Mini Tiller/Cultivator
20002 Saturn SL, replaced steering column. How do I...
Try to start the leve key on for 10 min, turn off (wait 10 sec) then try to start again and leve on for 10 min again, turn off and try again wait 10 min, turn off for 30 sec and then start engine.
Jul 26, 2009 | 1999 Saturn SL
The fridge is not cooling at all there is a clicking noise every 30 secs to one min. the model number is ptb1553grw
it sounds like a bad:
  •       start switch (on the side of the compressor) or
  •       compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps
(bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 14, 2008 | Maytag Refrigerators
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
