Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Reset code for le32r73bd - OTHER THAN INFO, MENU, MUTE, POWER
Got a samsung le32r72bd TV, and i need to reset it and the reset code (INFO-MENU-MUTE-POWER) shown on so many of the help sites does not work. any help?
    New Friend:
Jan 2016 --- Panzo's solution worked a treat, just remember to go into analogue, press buttons quickly, navigate to reset (option#12) and press left arrow which will remove the snow effect in analogue.
Thank you, and the rescanning worked without a hitch. Whew thanks again
Posted on Jan 07, 2016
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
  • 6 Answers
SOURCE: similar problem
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Is there any reset codes for a samsung LNT405HA
in service mode for service mode turn of the tv from the remote red button then pres one after another
info- menu-mute-power on (red button)
find reset IT WILL RESET THE TV TO ITS FACTORY SETTINGS
Sep 24, 2010 | Samsung LNT4069F TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung tv rest code
in order to reset a locked out TV you must contact Samsung technical support, they are the only ones that give you a override code to reset the lock out. the number is listed in your owners manual.
Mar 19, 2010 | Samsung DLP HL-P5663W 56" TV
Re: Samsung : LE32R73BD
hi yes there is, put the tv in standby, on the remote control press info, menu, mute, power the tv will come on with service menu just select reset,, if this don't work you will need to replace the maniboard thanks
shaun
Mar 22, 2017 | Televison & Video
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
1,651 people viewed this question
Jerry Greenberg
Jerry Greenberg
