Question about Sewing Machines
What are the common troubles of having sewing machine?
    Problem Solver:
  • 7 Answers
Buying more fabric thinking that you will make some great things and you stop in the middle of the project and you end up with many cut out fabric but never finish one single project. And your family think you can sew, they will ask you a favor to fix their wardrobe for free. It's fine if you enjoy it, or if you really want to stick with your plan and finish any project you start. Other, I suggest buy new machine, because you will get a good one to start and still have the warranty. Some dealer give you a free lifetime lesson (if its a portable home machine), which is nice since you can ask them a favor if you have some little challenge to be fix in the middle of something. Knowing the right thread tension for the fabric you are using can also be challenging.
Posted on Aug 02, 2010
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
Just turned machine on after being off and unpugged for a month or so and it is making a noise like a motor is running. any suggestions?
Question on sewing machine motors on vintage machines. - Sewing ...
artisanssquare.com > ... > Sewing Machines
Apr 28, 2010 - 20 posts - ‎4 authors
I've recently acquired 3 vintage machines a Singer 201 and 185 and a New ... When the motor is making some noise, but nothing is moving yet, that .... look - fragile, warped ? something like that anyway - in the first few turns.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ... Take the Trouble Out of Sewing Machine Troubleshooting! .... Problem #7: Themachine is trying to sew and making sewing-like sounds, but ..... My Brother sewing machine JX2517 just shut down while I was ... in or close to the motor.
Six Common Sewing Machine Problems Solved ' eBay
www.ebay.com > ... > Sewing Manuals & Instruction
Sewing machines sometimes seem to have a life of their own when it comes to working ... sewing problems can be fixed or prevented just by making sure themachine is... ... If the sewing machine is making uncommon noises, such as grinding or ... Do not use the machine when it is operating this way, and turn off power to ...
Let's Talk Sewing Machine Maintenance! ' LLADYBIRD
lladybird.com/2013/02/13/lets-talk-sewing-machine-maintenanc/
Feb 13, 2013 - At the risk of sounding like a big fat sewing machine snob, it makes me cringe ... I understand that it may not be common knowledge that sewing machinesneed regular ... If the idea of poking around in your machine just sounds too ...... now the tune up turn into oiling the most basic part of your machine, .
Jan 25, 2016 | Sewing Machines
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
Kenmore sewing machine 16520
Bobbin case problems are common, and usually bobbin race parts are easy to find and not too expensive if you need to completely replace them. Otherwise I have successfully sanded down burrs on cases and races if that is what the thread is snagging on... ? Without having someone look at how it is snagging, it is hard to diagnose. Hope you figure it out!
May 01, 2014 | Sewing Machines
My computerized Brother sewing machine won't come on.
this what i have found,,try this link. Fixing common sewing machine problems Service Support Brother Sewing and... ..
when you go to this page you will see this.. Fixing common sewing machine problems
Sewing machine manual.
Should you encounter a problem with your sewing machine, it's best to refer to the instruction manual supplied with your machine. This will contain details of the correct settings for your machine and may contain a trouble shooting guide.
If you don't have this most Brother sewing machine manuals can be found here ..
where it is saying,(can be found here) just click that.on the next page you just pick your model and you should be able to trouble shoot your problem from the manual..
or you could also go to this link and see if it helps you out.
My computerized Brother sewing machine won come on Google Search
Oct 27, 2017 | Sewing Machines
I do not have a manual and I need help in threading my older singer.
I found a free operation manual for your sewing machine on this website, called diplodocs.com
It's a pdf file-I downloaded the pdf file & looked at it & was inpressed with it,,,it shows the threading of the machine & other things you might find helpful
when you get to the website,,
go down to the middle of the page
there's a large rectangle box outlined in orange-called- most common searches
there are a bunch of sewing machine numbers,, look for your sewing machine number it is there,, & click on it & it will take you to a page you will have to answer 3 questions about your sewing machine & then you can download the pdf file manual-
I had no trouble getting it downloaded
hope this helps you
Aug 05, 2010 | Singer 3116 Simple
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
