Question about Mtd 22" Yard Machine Push Mower
I have checked the fuel and spark plug along with the filter on my yard machine 20 inch 3.75 horsepower machine, I just cant get it to fire, I started it yesterday but stopped to take a break and have not been able to start it again. Any suggestions?
  • 755 Answers
Recheck spark. You probably have a heat stressed coil.
The break you took gave the mower enough time to heat soak the coil causing it to fail.
Replacement coils are relatively inexpensive and if you have basic mechanical skills you can probably do it yourself if you want to.
Posted on Aug 02, 2010
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Intermittant no spark. Cruising along and shuts off like someone flipped a kill switch
Gotta be either fuel, fire, compression or timing, so next time it dies, spray a little starting fluid into the intake, if it starts right back up -fuel problem-probably stopped up fuel filter, bad fuel pump. If not, remove a spark plug wire and attach old spark plug , lay it on a grounded metal part of the engine or frame , have someone try to start it, watch to see if the plug is firing.
Apr 30, 2017 | Haynes Ford Pick-ups and Bronco Repair...
Yard machine y25 no start
Remove spark plug and pour in a small amount of fuel install plug and try to start it will fire the amount you poured in try this a few times
Mar 02, 2014 | Yard Machines Garden
How do I clean sticking valves on a briggs&stratton small engine
add a fuel system cleaner to the fuel tank and run the machine. you will want something that will get to the valves.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 12, 2013 | Mtd 22" Yard Machine Push Mower
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
2000 Grand Am GT: I need the firing order diagram for a 2000 pontiac...
2000 Pontiac Grand AM 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
May 17, 2010 | 2000 Pontiac Grand Am GT
I have a Tecumseh 4.5 2 cycle engine on my snow
fuel filter thats were i would check fuel will turn gummy in the filter if it sets
Feb 10, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | Yard Machines Garden
Mtd 22" Yard Machine Push Mower Logo
141 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
