Question about Cell Phones
My Blackberry 9700 ALT key is not working properly. I have to press ALT every 1 number, so if I would lik to type 10 number I have to press ALT 10 times. I did: 1. Restart / Reboot 2. Unplug my media card 3. Memory Cleaning 4. ALT LGLG Please help me. Thanks
I have the same problem. I've had the bold 9700 for only 2 weeks. If you had any luck fixing it please let me know.. aalylermaa@hotmail.com
Posted on Sep 21, 2010
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
I need a free unlocking code for my blackberry bold 9700.. can someone please help me ??
GO TO http://www.blackberryfaq.com/index.php/How_do_I_unlock_my_BlackBerry%3F
Mar 29, 2012 | RIM BlackBerry Bold 9700 Smartphone
Ihave an unlock code from AT&T but I need the step-by-step unlocking procedure from you. What do you charge for that?
How to Enter Unlock Codes on BlackBerry Bold 9700:
This procedure works best with the original SIM card in the phone (can be active or inactive). Make sure the phone is not displaying the low battery warning!
  1. Power on
  2. Go to settings
  3. Go to advanced options
  4. Go to sim card
  5. Type MEPD
  6. Type MEP[Alt + 2]
  7. It will ask you for the Blackberry unlock code. Enter it and your phone is unlocked!
Apr 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
Not able to unlock. GETS STRUCK AFTER MEP2
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Mar 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
Blackberry 7290 unlock proceedures
Hello.
I think I see your problem.
The 'mepd' must be uppercase. Hold the shift key down while typing in the MEPD.
Once you get into the area that shows what limitations are active or disabled, then you must use the Alt. Option key on the fare left third row of keys down. Holding the Alt. Options key, type MEP then release the Alt. Option key and press 2.
You should now be prompted to enter the unlock code. If not, start from where you had the last correct results. Also, If it will not work, back all the way out to the memo icon and try the keys you need to type to insure all of the keys are working and you are not fighting a temperamental key switch.
Good luck in your quest.
If you still need more help, just ask.
Oct 17, 2008 | RIM BlackBerry 7290
I can't dial out.
The Phone application on the BlackBerry smartphone automatically converts phone numbers that include letters into the associated numbers.
To key a phone number that contains letters, press the right Shift key or the Alt key and type. The letters appear on your screen, but the BlackBerry smartphone translates them into the appropriate numbers when the phone call is made.
For example, to call 1-877-BLK-BERR (1-877-255-2377) from your BlackBerry smartphone,
  1. Open the Phone application.
  2. Type 1877.
  3. Press and hold the Alt or right Shift key and type BLKBERR.
  4. Display the menu and select Call 1877BLKBERR or press Enter. When the phone number is dialed, the letters are converted to numbers on the screen.
  5. To end the phone call, hold down the Escape key.
To return to the Home screen from any other screen, press the End key.
To lock the device, set a password. Hold the * key.
To unlock the device, press the * key. Click Unlock. Type your password.
To lock the keyboard, hold the * key.
To unlock the keyboard, press the * key
To switch the input language, hold the Alt key and press the Enter key. Continue to hold the Alt key and select a language. Release the Alt key to switch to that language.
To switch back to your original input language, press the Alt key + the Enter key.
I hope this helps
Please remember to rate this solution.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
Cell Phones Logo
379 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
