Question about ASUS P4S800-MX Motherboard
Suggestions Dear Experts, I have pc P4S800 MX , due to problem with cpu and motherboard I like to replace my cpu and mothered. Could any one suggest few motherboards and cpu, so I can use with my all existing components. Existing components are, Advance 230 volt power supply, 20 pin and 4 pin connectors to motherboard DDR 333 (2.5) 516 MB*16 ram (one stick), Form factor micro atx Size 24.4 *24.4 thank you very much for your time.
  • ASUS Master
  • 13,433 Answers
Hello, I would recommend you upgrade your powersupply, memory, motherboard and cpu.
This is a cheap configuration good for basic computer use, vista ready. If you want gameing you will need better parts to play the newest hits.
As the motherboard, clearly not for playing games. I would recommend:
ASUS P5S-MX
As for the CPU I would recommend this model witch works with the motherboard I have selected:
Core Duo 2 E4500 2.2GHz, 2MB, FSB800 Boxed (boxed means it comes with a heatsink+fan)
As for the memory I would recommend the cheapest 800MHZ DDR 2 you can find, heres what I found
1GT DDR2 800MHz, Vitesta, 240-pin DIMM
Buffalo also samsung have these for cheap prices.
I would take two of those. for the motherboard.
You might not need to replace your powersupply, but a adapter from 20 pin to 24 pin would be required.
You can buy a cheap 350W or better Powersupply with 24pin connector.
Ask advice from your dealer also, and buy from a real computer shop instead of the wallmart for example.
this configuration with a 350W powersupply would cost 220€ here where I live.
thats 343 usd.
Posted on Apr 25, 2008
  • Ekse Apr 25, 2008
    also if the parts dont fit into your case, but they should, then you need to buy a new case, get a cheap 20e model thats 31usd.
    But as I dont live where you live the prices can be difrent.
    Master:
  • 518 Answers
DDR 333 memory is DDR PC2700, I believe. It might be hard to find a new MB that will work with that. You'll probably have to buy new memory. You'll also need a new CPU fan, unless you know the Socket type of your existing MB. But you should replace the fan anyway on a new CPU/MB install. You should buy as much memory as you can afford.
Try looking HERE and see if anything is in your price range.
Hope that helps...
Geno
How to put the on/off wiring to the asus p4s800 motherboard
Hello
In your lower right side of your CPU there are connectors which is intended for power switch and reset switch which is used turn your power on and off in your CPU. That connectors are connected to a normally open switch. Or you can even short it with a small wire to turn on you PC. If you want to automatically power on download on this software on this site http://www.lifsoft.com/
Hope this can help you..
Jul 19, 2011 | ASUS P4S800-MX Motherboard
Changed out power supply, now can't get video to work
pls ckh ur power supply 5v 12v again other wise change power supply.
pls, chk it is at,or atx power supply.
or ur mother disply ic is damage
inset new display card.
Feb 23, 2010 | Intel ASUS P4S800-MX SiS661FX Motherboard...
What computer models was this MB used in?
This MB is used mostly in Pentium 4 (P4) PC model.
however, I don't know which particular brand. My PC is an IBM P4 2.4GB. Since the original MB got busted, it was replaced with ASUS P4S800-MX., and it works just
fine.
Nov 12, 2009 | ASUS P4S800-MX Motherboard
No available cpu localy
ebay or newegg ( http://www.newegg.com ) if you are in the uk then www.aria.co.uk or www.dabs.com or www.misco.co.uk
Apr 18, 2009 | ASUS P4S800 Motherboard
PC wont boot, not even to bios
Maybe the mobo is shot for u and he has his PSU shot.......Check for any burnt smells from the mobo. See if the cable from the PSU is properly connected to the mobo. Try removing all drives like graphics cards, RAMS one by one and see if it works.
Aug 18, 2008 | ASUS P4S800-MX Motherboard
Upgade motherboard
What problem is it that you are having?
If you want to upgrade you're CPU here is the Asus link for supported CPU's P4S800-MX motherboard.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4S800-MX
To the right of the list is the bios file that must be used to support the CPU.
If you need instruction on how to replace a CPU just let me know.
Mike
Jul 21, 2008 | ASUS P4S800-MX Motherboard
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
Display problem
Hi nashna,
Click on this link I have posted. You should find some Asus help with-in this site.
http://in.asus.com/910/html/aboutasus/aboutasus3.htm
Good Luck!
Mike
May 02, 2008 | ASUS P4S800-MX Motherboard
Asus p4s800-mx
The problem is most likely bad capacitors. The may have used a bad batch, with many people having such issues. I understand it is difficult to get several of the caps out without ruining the board completely, so it may not be worth the time and effort it would take to replace them.
Oct 10, 2007 | ASUS P4S800-MX Motherboard
ASUS P4S800-MX Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
