Question about Turbo Air TPR-67SD
TUBROAIR TPR67SD. UNIT FREEZES UP WHEN EVER IT FEELS LIKE IT?
  • 11,800 Answers
Do you refer by that to the fact that your pizza table stops to operate or that it simply stops freezing but the other components (fans, louvers, etc.) are still working? If it's the first then the unit no longer receives power - check the wall socket, the cord and the main switch.. If it's the second then the thermostat is faulty - replace it.
Posted on Aug 02, 2010
  • arch_01 Aug 02, 2010
    IS THE COLD CONTROL A STANDARD UNIT? OR IS IT A SPECIAL ONE? IF SO WHERE DOES ONE GET?
    BILLY
  • Azrael SRL Aug 02, 2010
    There is no standard one, and each model of cooler has his own model of thermostat. Unfortunately you can get it only from the manufacturer and from what i know only them are selling the parts.
    Here is the repair manual
    http://www.turboairinc.com/TB-Service/Se...
    the wiring diagram is at page 4, follow it to locate the faulty part. At page 9 you will find the parts code, use the code to order a replacement.
Outside unit freezes up
the unit must be in heating...
when we heat the room we effectively refrigerate outside to gain heat and put it to the indoor unit, hence the outdoor coil freezes up, it should defrost every now and then but each unit is individual..
check your settings
cheers
Jul 03, 2010 | Heating & Cooling
Kenmore - ice maker won't produce but water in door fine
Most of the times the solenoid ( electric valve that lets water from the line when the ice maker calls for it) leaks and this little water freezes up inside the filling tube for the ice maker , in tnis case the solenoid has to be replaced.
Oct 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezes
Your defrost system has gone out and the unit freezes up because there's no way to tell the unit to defrost. Call us with brand and model number and we'll be sure to get the right parts out to you asap. Hope this answers your question.
Sep 16, 2009 | Refrigerators
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
My psp doesnt turn on/freezes
If you can... test it out using a friend's battery..
But if it's freezing, sounds like a main board issue.
Mar 08, 2009 | Sony PlayStation Portable (PSP) Console
Turbo Air TPR-67SD Logo
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
