Question about Samsung Computers & Internet
We couldn`t be able seen the real colors on the monitor.Displaying in almost white colors.
    Problem Solver:
  • 14 Answers
Use the monitor to turn the brightness down
Posted on Aug 02, 2010
Delayed reaction and white colors
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Acer V193w LCD Monitor
New hardware installed, printer added and screen is now in varying shades of green. How can I restore the color to normal?
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Dec 21, 2011 | Acer X233H 23" Monitor
My monitor displaying yellow color in place of white
right click on the desktop ...properties...settings (should be the last in the right ) ..than advanced..and should display the monitor settings ..there get them one by one cause there are more then one setting and try to default them ...i fthe color is not getting to normal than reinstall the video card ..and after that if is still the same it means that something is broke in the monitor ...and need a proper fix..at the shop ...or ..if it is a cheap one ..just get another form a second hand dealer until you will afford a good one ..
May 09, 2010 | LG Studioworks 700S 17" CRT Monitor
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
Computers & Internet Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
