Question about Canon PowerShot SD1000 Digital Camera
I put my memory card in my camera and it has a message that says no memory card. What do I do
  • 35 Answers
Try blowing dust off of memory card and memory card slot if that does not work try restarting camera and/or inserting memory card again.
Posted on Aug 08, 2010
  • 906 Answers
I suggest you to turn off your camera and then turn it on. Or you can also re-insert the memory card.
Thank You.
Posted on Aug 02, 2010
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Memory Card is Full error message
The camera uses either SD or MMC cards, it is likely you bent or broke one or more of the connector pins in the camera..Bent pins usually break if you try to straighten them.
Repair costs will probably cost as much as a replacement new camera. On eBay you can buy a C330 for $10-
$40.
Sep 04, 2017 | Kodak EasyShare C330 Digital Camera
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
May 11, 2009 | Nikon COOLPIX 5100 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
try to reformat that card via a card reader/writer.. then reformat it using the camera thru the menus.
Nov 29, 2008 | Canon PowerShot A710 IS Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
