Question about Goodman Heating & Cooling
What the compressor model number in a Goodman CK24-10
  • 148 Answers
SOURCE: I need a fan motor for goodman AC compressor model
depends on where you live there are supply houses that carry goodman products the motor is a 3 1/2 ton unit or bring the motor to motor shop they can cross reference that number to another motor that would work fine
Posted on Jun 30, 2009
pierre1811
  • 144 Answers
SOURCE: Need to know how to find out how old my furnance & air cond. is
1993
Posted on Mar 31, 2009
james3751
  • 614 Answers
SOURCE: My compressor works itermittantly. I was holding
A hard start kit always helps. Take a reading inside. Temp at the return air and temp at the closest grille. Subtract and that temp should be between 19 to 23 degrees. If not you have other problems. Contact service tech for free estimate. Possibly a little low on refigerat, Rus
Posted on Jul 05, 2009
  • 3 Answers
SOURCE: I have a goodman 2 ton condeser model number
Yes. The condenser is 1.5 ton and the larger coil will allow for better dehumidification but do not go any larger. Make sure when installed that bioth super heat and subcool are measured to insure proper charge and that system is working at peak performance.
Posted on Aug 14, 2009
  • 9 Answers
SOURCE: Does anyone now the compressor OEM (i.e. copeland)
The tag is on the compressor itself. This particular model has had several compressors during its lifetime.
Posted on Jun 17, 2010
What is the compressor part number for a Goodman heat pump model PHKJ036
ZR32K5EPFV800 is the OEM part number. I have to ask why you believe the compressor is bad.
Feb 24, 2017 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
I have a Goodman Model CPLE24-1A, Serial # 0207416067. First, can you tell me how old the unit is? Next the fan comes on in the outside unit and it sounds like the compresser trys to start but cant no
Hello, based on your serial number It looks like the unit was built in Feb of 07. If the compressor is trying to start you may either have a bad capacitor or one of the windings in the compressor is open. Start by replacing the capacitor as it is inexpensive, if it does not work than looks like your compressor will need to be replaced.
Jun 04, 2012 | Goodman CKL24AR24 Air Conditioner
When was the goodman model CKL36-LL serical number 0504211625 produced
The first two digits of the serial number are the year (2005) and second pair of digits are the month (April).
May 26, 2012 | Goodman CKL36AR36 Air Conditioner
Does anyone now the compressor OEM (i.e. copeland) and part number for a goodman A/C model CKL49-1?
Jun 16, 2010 | Goodman CKL36AR36 Air Conditioner
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
I need a fan motor for goodman AC compressor model #CK-42-1C Serial number 9905596387
Jun 30, 2009 | Heating & Cooling
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
259 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
