Question about Zebra LS4278 Cordless Bar Code Reader Barcode Scanner
I have a symbol LS4278 scan gun. When I place the gun in the cradle it blinks with an amber light. In the documentation that says that it has a "Critical battery temperature fault". I replaced the battery with a new one but it still does the same thing. Could it be that the cradle is no good, or maybe a problem with the scanner itself? Thank You.
    Scholar:
  • 117 Answers
Hello Lynda,
this seems to be an error with the charging system of the scanner. As you stated the error occurs also with other battery. Just check if the scanner is in warranty and send it for repair.
It could work also with this error, but the charging will not work correctly. As the temperature error is safety measure which stops the charging until the status get changed.
Posted on Sep 08, 2010
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
LS4278 no laser
There are three possibilities I can think of assuming this is not a brand new scanner:
1. The LS4278 is faulty - which given Symbols quality I would say it is normally not the case unless th scanner has been dropped or otherwise damaged.
2. The cradle is not charging the scanner. You may wish to try another cradle - one that you know is charging aother scanner. After a few minutes you should be able to see the laser.
3. The battery in the scanner either needs a recondition (see product reference guide), or needs replacement.
Apr 14, 2014 | Symbol LS 4278 Barcode Scanner
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
When my scanner ls4278 is on the cradle it has a solid red light? I can't find in the manual a meaning for this.
I was also unable to find a solution for you. There are only supposed to be 2-leds in the cradle, 1-green and 1-amber. Maybe it is a battery temp fault, and it has somehow been misread. If you have another docking station and another gun, try swapping them to see where the fault lies. If on the good station the gun shows the same error, you know the fault it with the gun, not the cradle. Hope this has helped!
Mar 03, 2011 | Symbol LS 4278 Barcode Scanner
LS4278 scanner can't read digits
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
Oct 16, 2009 | Symbol LS 4278 Barcode Scanner - P/N...
How can you use a symbol model ls4278 with a usb converter for the ps/2 plug?
The scanner will probably give you error beeps because you are not using a PS/2 keyboard. All you should have to do is scan the IBM AT Notebook barcode from the LS4278 Product Reference Guide. The link below will take you to the manual and the barcode is on Adobe page 104 of 418. I would suggest saving a copy then printing just the page you need.
If the scanner does not start working immediately you should reboot your computer.
LS4278 PRG:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983403apdf&sliceId=&dialogID=116526806&stateId=0%200%2011869362
Jul 21, 2009 | Symbol LS4278 Handheld Barcode Scanner
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Zebra LS4278 Cordless Bar Code Reader Barcode Scanner Logo
1,198 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
