Question about Soyo MT-NI-DYLM2058 Monitor
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
    Problem Solver:
  • 14 Answers
If the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Posted on Aug 02, 2010
How do I set up a 19" coby TfT lcd TV
Plug it in to the mains plug, plug in your inputs and then power it up. If it says no signal or something similar, try scanning through every single input on the menu until something comes onto the screen.
Jan 02, 2016 | Coby Televison & Video
I have a 19 inch Gateway HD monitor. The model number is LP1925. When I boot up everything is normal. However, after about 5 minutes the screen goes black. I can't get the picture back unless I pull out...
I see that this monitor has a DVI input, in additon to the VGA input. I suggest getting a suitable cable to use the DVI input, to see if the fault replicates. If it doesn't, you have identified the problem - an issue with the analogue signal processeing circuitry in either the monitor or the computer. The monitor's auto sleep analogue circuitry, for example, may not be sensing a signal, and going to sleep. BTW, if you use a DVI-DVI cable, you avoid the video signal ever going through an analogue stage, and the image will also be purer.
Dec 16, 2017 | Gateway 19" Widescreen Flat Panel TFT LCD...
I was given a Soyo monitor, model; DYLM1988, that starts but only stays on for a few seconds. What are some possible problems and what could I try to fix it?
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please find below two links for tips on poor start ups, as if the set is totally failed the SMPS might be faulty
Soldering tips:
Slow start of circuit
Nov 16, 2010 | Soyo TFT 19" LCD Monitor
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Soyo TFT 19" LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Everything is too big on the screen when I get on the internet
Try selecting a much higher resolution from the menu
1650x 1200 should be ok for a 19" or 1260x760 or something within those parameters
Please rate my help++++Thanks for using FIXYA
Oct 20, 2009 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Power
check power cable and change if needed.
Jan 22, 2009 | Soyo TFT 19" LCD Monitor
Soyo MT-NI-DYLM2058 Monitor Logo
257 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
