Question about Kenmore 19110 Computerized Sewing Machine
My machine locks up after two stitches.. I have removed the bobbin, clean it out, changed the needle - to one that came with the machine... very frustrating.... the machine is 6 mos old and I used it eysterday with same thread/needle/material.. Help.. I'min the middle of a project... Can't seem to find a solution in the manual.
  • 135 Answers
The threaded isn't seated between the upper tension disc
Posted on Aug 14, 2010
The machine locks up with the needle in the bobbin case and cannot raise the needle with the hand wheel.
Could be some threads or gunk buildup in the bobbin area. Also, could be a needle/hook timing issue. If cleaning it thoroughly does not improve the situation, you may need to take it for service.
May 28, 2016 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
Sewing machine will do a few stitches and then lock up. I get the LO error message
try changing the needle
rethread the machine top and bobbin
clean under the needle plate and in the bobbin area lint
make sure the bobbin is inserted correctly and also that the bobbin
is turned the right way in the bobbin holder.
or the machine may need to be checked to see if a part has some
thing wrong with it
Nov 19, 2012 | Sewing Machines
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Sews small stitches on the top and loose stitches underneath from the bobbin.
change needle
change your stitch length dial to a number higher like if it on 3 change it to 4 or 5
change the tension to 3 or 4
clean under the needle plate where the feed dog is for lint
clean the bobbin area for lint or loose threads
Nov 22, 2010 | Baby Lock Ellure
Makes too much noise
Check that your needle is fully up into the needle housing, and is in flat shank to the back.
Also change the needle if it has been in the machine for more than 6 hours of sewing as the needle will go blunt and this can make squeaking or popping sounds as you stitch.
Lastly, are you sure that the bobbin case is in correctly and hasn't been put in incorrectly. It should have a stitch finger which locks up into the top of the rotary hook if its a vertical bobbin case and bobbin design which I'm pretty sure your machine is.
Jul 27, 2010 | Elna 2005 Mechanical Sewing Machine
Kenmore 19110 Computerized Sewing Machine Logo
95 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
