Question about GE Washing Machines
Recall on GE front load washer Model # WBVH5200J3WW Serial # TR206310T We have this machine and need to arrange an appointment for someone to take care of it.
dauphine
  • 207 Answers
SOURCE: front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Posted on Apr 20, 2008
  • 1028 Answers
SOURCE: how do i remove top or front cover on GE washer
2 clips 1 one each upper corner about 3 ins in use putty knife to release clips pull panel forward at top and lift off
Posted on Nov 20, 2008
SOURCE: Have to change bearing on front load washer
The bearing numbers are 6306-2rs and 6307-2rs which go with seal # G059 which I sell on Ebay.
Posted on Apr 22, 2009
SOURCE: FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
Posted on Aug 17, 2009
  • 1015 Answers
SOURCE: i had stored my ge frontloader washer and dryers
I would remove the back and investigate for mouse/rat damage. If you had them in storage a rodent may have made himself a home. They like to chew thru wires and plastic components. Or a wire connection may have come loose when you moved them into storage or back from storage.
Posted on Sep 25, 2009
I've got a ge front load model wbvh5200j3ww. Start wash cycle door locks drum turns one direction then the other then door unlocks. Nothing else happens
Sounds like you have a bad board and needs to be replaced.
Is this washer under warranty and if not did you take out an extended warranty?
Aug 27, 2014 | Washing Machines
Ge wbvh5200j3ww
Hi Jennifer,
Here is a link to the USER'S MANUAL for that model of washer:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90392-2.pdf
Just click on the underlined text above to view an electronic copy of the manual.
On page 8 of that manual you will see instructions related to the LOCK feature on your washer.
It says that to LOCK or UNLOCK the washer, just hold down the DELAY START button for 3 seconds. The lock icon on the display should then disappear.
If that does not work for your model, then try holding down the SIGNAL button for 3 seconds.
One of these two procedures should solve your problem.
Hope that helps.
Take care and thank you for using FIXYA.
Joe.
Jul 24, 2013 | General Electric WBVH5200J Front Load...
Lights flashing
Please help get GE to recall these front loading washers! Sign our petition: http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Jul 04, 2013 | Washing Machines
GE wpdh8900jmg front load does not go to highest speed spin. It does go to the lower speed spins
call your G.E. authorized dealer because theres a recall on this unit,or call G.E. directly or go online to find out how to get warranty service at NO COST to you,as theres a problem with these machines and the problem your having is a recall issue by GE company,the unit needs to be re-programmed during spin or theres a chance the basket can breach the top cabinet during spin cycle call them SOON,all serial numbers for that model are covered under this warranty
Nov 19, 2012 | General Electric WPDH8900JMG Front Load...
We have a 2-year old GE washer WBVH5200J3WW brought from HomeDepot. It leaks water from the bottom. Any suggestions are appreciated.
Just started having the same issue (ours will be 2 yrs old next month) we are thinking its the rubber seal tube around the front that is worn out....
Jan 16, 2011 | General Electric WBVH5200J Front Load...
Can the door swing on a GE wbvh5200j3ww washer be switched?
AFTER PUSHING THE START/PAUSE BUTTON IT JUST BEEPS AND WILL NOT LOCK DOOR AND ELECTRIC SUPPLY IS GOOD
Nov 17, 2009 | General Electric WBVH5200J Front Load...
I had stored my ge frontloader washer and dryers for about 4 months and reinstalled them i turn the washer on and it runs threw its cycle and does not spin so the close are soaked in the washer the model...
Sep 25, 2009 | GE WSXH208A Front Load Washer
Aug 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at www.samsung.com/washerrecall.
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Washing Machines Logo
932 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
