Question about Pro RX55 Radar Detector
My Beltronic RX55 show Cal.? I have to shut it down and then power on. What does it mean & how to fixed it
What dose Cal means its showing on my radio when i try to start my car
Unfortunately the CAL ERR is inside the radio and it requires a scan tool to reprogram. There are shops that are not a dealer that can do this programming. There is no code or sequence that I can give you to unlock or fix this. If there was, rest assured I would, but there is not. check with local stereo shops
Apr 24, 2016 | 2001 Chevrolet Impala
What does the word CAL mean that shows on the dash
CAL stands for Calibrate. The IPC (instrument panel cluster) needs to be recalibrated. This could becaused by a battery/power spike, which means the IPC will need to relearn default settings, or therecould be an underlying problem. Technician will need to hook it up to a computer to analyze problem,and relearn settings.
Nov 03, 2013 | 2006 Chevrolet Impala
How do you tune cb radio 75wx st
Not sure what you mean by tune.
If you mean peak and tune, where in you increase the internal power output of the radio, then the quick and dirty way of doing it is, turn VR4 all the way to the left and take the tank slug out of L14. HOWEVER, I prefer to use a watt meter on avg power to adjust L14 to peak, and no more as not to over bias the final. But typically nothing will happen if you do. This will give you full modulation, and full carrier.
If by tune you mean, Tuning the SWR. Then that is a whole different topic.
In this case you don't actually tune the radio. You tune the antenna. If the antenna is not the correct length, relative to the wave length, Frequency of transmission..... then you will have a high SWR and this means more of your RF energy is not leaving the antenna, and going back into the radio. This is bad. this kills radios.
So to tune it you must make the antenna the right length. Here is how to check SWR.
Tune the radio to ch 20. Put the rf/SWR/CAL switch to CAL.
Turn the CAL knob all the way to the left.
Key the radio, and turn the CAL knob to the right until the needle of the meter is at the CAL mark, on the top line of the meter indicated by a little upside down triangle. That is the cal mark. The needle should be on it.
Flip the RF/SWR/CAL switch to SWR while holding the key down.
The meter is now showing your SWR. If it is under 2 you are not real good, but not gonna kill the radio. If you are 1.5 or less you are good to go. Ideally you want to be 1.5 or less if you can.
If it is over 2 you should try to get it lower.
here is how to find out if the antenna is too long or too short.
Turn to ch 1, repeat the steps to check SWR. Then do the same thing on ch 40. Compare the reading. If the reading is higher on 1 then on 40 the antenna is too short, and you need to make it longer. If it is higher on 40 then 1, it is too long and you need to make it shorter.
All antennas have a way of adjusting the length.
Hope this helps.
Aug 10, 2012 | Radio Communications
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
My ANT light comes on when ever i push the mic button but my SWR isnt that high
The meter will be more accurate and an external meter will be even better. If they show good disregard the ant light it is adjustable. It may have been set to sensitive from factory. These erroneous SWR reading can be the side effects of a PEAK & TUNE if the coils have been spread but that should also show on meter.
SWR meter calibrations
  • Switch (S/RF SWR CAL) to the CAL position.
  • Push and hold mic button
  • While holding mic button adjust the SWR CAL knob so the meter needle swings to the CAL mark on the meter
  • While still holding down the mic button, set the (S/RF SWR CAL) switch to the SWR position, to read the SWR reading. Note: When switched to SWR position the meter needle should ideally be as far to the left as possible. Anything over 3 is not acceptable.
Jul 28, 2011 | Cobra 29 LTD CB Radio
We use the Ohaus CS 200 and it shows "E" (error?) What does that means and how can I get it to normal measure
Ours does that too. I hold both the "Unit/Cal" button and the "On/Off/Zero" button down at the same time until the "E" changes to "Off" then release both buttons at the same time. The screen goes blank. Then I hold down both buttons at the same time again until "Cal" comes on for a split second, release both buttons and the "Cal" switches to the normal "0" ready to weigh screen.
Feb 04, 2011 | Ohaus CS200 Standard room Scale 200g X1g...
Cal??? Keeps apearing on my display? It is a BEL Pro RX55! Can anyone help me? Thanks, Mark N.
That means Calibrate. You must calibrate your unit as per your manual. below
www.radarshop.com/manual/rx55manual.pdf -
Mar 10, 2010 | Vehicle Parts & Accessories
Pro RX55 Radar Detector Logo
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
