Question about Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard
How to connect front pannel
I got a new motherboard now but i dont know how to connect a front pannel. please help me step by step.
thank you.
    President:
  • 2,351 Answers
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Posted on Apr 25, 2008
It is same for my P5KPL AM/PS front pannel is not working for this mainboard. My OS is windowdow xp 7
For that you need to check the front panel connection to motherboard. You can see diagram below . Click here Download manual from below link then connect front panel connection to motherboard. You can also find the diagram on motherboard there are some pins on corner of the motherboard where you need to terminate front panel connection. You can read diagram near those pins. Let me know if you need further assistance. Thanks for using FixYa.
Nov 28, 2010 | ASUS P5KPL-AM SE Motherboard
Need wiring info for front pannel on6787
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 29, 2009 | MSI Computers & Internet
Usb connection????
Check this manual here ... it should give you how to get the connections done.
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5SD2-X/E2026_P5SD2-X.pdf
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Analog front panel conections need map to board connections
Here your connection...
Front pannel
http://www.geocities.com/jisfy/Front-P.JPG
Front Pannel Usb Connection
http://www.geocities.com/jisfy/USB.JPG
Thanks if it helpfull please rate me.
Mar 26, 2009 | Biostar M7VKQ-PRO Motherboard
I need the pin cinfig, for the front pannel
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 01, 2009 | MSI MS-6580 Motherboard
I have msi945 board
Try checking the front panel in bios. It may be disabled there which would mean the front panel jacks would not work. Hope this helps.
Dec 19, 2008 | Intel Motherboard
Front pannel connection regards
there are small input adapters lying unused in your cabinet.just connect them to the incoming adapters and you are done.
Oct 24, 2008 | Mercury P4VM800M7 Motherboard
Help pls....
http://www.intel.com/products/i/motherbd/D946GZIS/D946GZIS_lg.jpg
connect the front panel audio to the yellow coloured header you can see near the white coloured PCI Slot. in the above picture it is shown in the top right hand corner.
Dec 24, 2007 | Intel D946GZIS Motherboard
Flash Disk goes bad
Did you assemble the board yourself into the case? check to make sure your front panel USB connections are installed onto your motherboard in the correct order. Refer to your Motherboard Manual.If they are not, they can fry your usb devices rendering them inoperable on your pc or others. I have seen this before because of improper installation of front pannel USB connections. Good Luck
Apr 09, 2007 | Intel D915GUX Motherboard
Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard Logo
502 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
