Question about McCulloch Trimmer Plus Attachment: Add On Turbo Blower
What is the gas mix on a 5 year old Mcculloch weed trimmer. I got it for free and dont have the manual. Its yellow.
3 Suggested Answers
panilling9
  • 284 Answers
SOURCE: I'm looking for a free downloadable owners manual
spark plug gap is .025
spark plug recommended for this trimmer is DJ8J
Or RDJ8J if you dont want radio interference or if you do not like champion plugs NGK isMB6F
torqed at 110-120 inlb.
Posted on May 27, 2009
  • 430 Answers
SOURCE: My McCulloch MB 290 runs for 5 minutes and then shuts down. Mix in the tank is 1 month old but is correct.
Could be several different things. Carry a can of carb cleaner with you and run it till it quits. Then remove the air box and try to start again, try using the choke, try a squirt of carb cleaner in the carb ( not at the same time ). If it tries to run then its a fuel issue or an air leak. If it wont run then its got low compression or a bad ignition.
Posted on Oct 25, 2012
What is the gas mixture for a McCulloch 2816 weed trimmer
Check the resources below for gas/oil ratio:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
Oct 06, 2014 | McCulloch 2816 Edge Trimmer 28cc
McCulloch MAC 60 SX trimmer fuel mixture ratio is?
Check the links below for fuel/gas ratio.
Contact us
User manuals McCulloch Service
I trust this information proves beneficial.
May 26, 2014 | McCulloch Trimmer Plus Attachment: Add On...
I have a McCulloch 100HD weed eater and i'm not sure what kind of fuel mixture to use for it. Do you know what's the ratio mix and what kind of mix should I use?
Contact us
User manuals
McCulloch Service
I trust this information has proven beneficial.
Aug 24, 2013 | McCulloch Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a canon lawmower which is a two stroke engine and it is at least 20 years old so i have unfortunatley lost the manual over the years. It has recently ran out of oil so i have bought some more but it...
Serena you are all wet, literally. You mix oil and gas, not oil and water as they do not mix and will cause total failure of the engine.
You can buy little bottles of 2-stroke oil at auto parts stores and wal-mart and they will have written instructions right on the bottle as to how much gas to add to them. Generally one little bottle to 2 gallons or so of gas it is not critical, especially on a 20 year old engine. I use the same premix on chainsaws, hedge-trimmers, weed-eaters, etc.
Jul 07, 2011 | Garden
Weedeater starts and immediately shuts off. I checked the fuel filter and replaced the plug the unit is 1 year old.
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
May 05, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Does 2 cycle oil get mixed with gas on McCulloch chainsaw or just put gas in?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 14, 2009 | McCulloch Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
McCulloch Trimmer Plus Attachment: Add On Turbo Blower Logo
110 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
