Question about Cell Phones
I want jaf driver 7.0.2.0 - Cell Phones
Jaf box not detected in computer
Is your computer detecting it as a new device/hardware? What OS is on your PC? Different OS's word their messages differently BUT all mean the same, i.e. need more info before can suggest a solution. Some drivers need to be sometimes installed manually, just depends on System. If other USB devices are detected by your PC than it is more likely to be the Jaf box or USB cable. That's all I can suggest at the moment.
Apr 29, 2013 | ODEON JAF FLASHER INTERFACE
I have forogotten the security keyguard of nokia 6300, how can i reset the defaultcode?
USE J.A.F TOOLS AND REFLASH YOUR DEVICE
1)DOWNLOAD SETUP FROM HERE www.mediafire.com/?8tii1p2dw38en39
2)DOWNLOAD LATEST FIRMWARE OF YOUR MOBILE
UNPACK NOKIA FLASH TOLLS AND INSTAL JAF
COPY NOK4MODEL.INI TO C/PROGRAM FILE/ODEON/JAF
DELETE ALL JAF ICONS ON DESKTOP
COPY AND PASTE OGM PKEY ENUMULATOR TO DESKTOP
INSTALL FIRMWARE
INSTALL LATEST NOKIA PC SUIT
1)RUN OGM PKEY AND GOT TO STEP 2 AND CLICK ON LAUNCH JAF AND GOT TO BB5
2)UNTICK ALL THE DEFAULT TICKS
3)TICK ON DEAD USB,MANNUAL FLASH AND FACTORY RESET
4)TICK USE INI.JAF WILL HANG FOR A WHILE.A DAILOG BOX WILL OPEN
AND THEN SELECT YOUR MODEL
NOW YOU WILL SEE THREE GREEN LIGHTS ON MCU,PPM,CNT,THIS MEANS ALL IS OK
NOW CLICK ON FLASH,AN ERROR WILL SHOW UP CLICK YES
NOW CONNECT YOUR SWICHED OFF HANDSET WITH PC BY USB CABLE AND SHORTLY PRESS POWER ON
JAF WILL DETECT YOUR PHONE AND WILL FLASH YOUR HANDSET ALSO IT WILL RESET THR USER SETTINGS LIKE SECURITY CODE ETC
NOTE:- ALWAYS USE LATEST FIRMWARE.DOWNGRADING WILL KILL YOUR PHONE.DO AT YOUR OWN RISK
May 02, 2012 | Nokia 6300 Cellular Phone
How to flash nokia 3110c
Jaf box supports Nokia 3110C and many more other Newer nokia models, you can flash it using Jaf box with all the necessary cables and database. If you don't know what is jaf box and what is meant by flashing, I don't think you can do that. Flashing needs specific hardware and software, you can't simply flash it on your computer unless you have the required softwares and hardwares.
Note: Jaf box and all it's accessories will cost you twice the cost of Nokia 3110c and most importantly, you need training and experience to use them.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 01, 2011 | Cell Phones
I need jaf flasher interface I use the version 1.98.62 and emulador v 10.0 firmware 01.B1
You can find the drivers for your device here:
www.driverguide.com
Sign up for a free account.
Mar 07, 2011 | ODEON JAF FLASHER INTERFACE
I want to reinstall flash for my nokia 5220 mobile can u tell how to proceed this
Its best to get your phone flashed from a service centre. However, you can flash the phone yourself. Step by steps instructions are given below:
1. Download navifirm from here.
2. Select your phone model and download the latest firmware available.
3. Download JAF from here.
4. Flash your phone with JAF using dead usb option. (How to flash with JAF)
Hope it helps. Please rate the answer. Thanks for using FixYa.
Jan 11, 2011 | Nokia Cell Phones
How to flash my nokia 5310??? i'm having JAF and firmware files also and JAF is not working in windows 7 help me
the problem is you are using windows 7 , it does not supports some of the old version of software, try to download new software from official size for win7, or try to format using phoenix by usb cable
here is tutorial how to format using phoenix
http://www.fixya.com/support/r5875102-format_nokia_mobile_phones_3110c_2700c
Sep 28, 2010 | Nokia 5310 Cellular Phone
I NEED RESTRICTION CODE FOR MY NOKIA 3220
restriction code can't be fix it by a manual code.
because restriction code is meaning if the system in the phone is corupt or damage.
you have to use a flasher Dongle box
like UFS3 Tornado,JAF,HWK BOX,MT BOX,etc.
you better bring your phone to Cervice center.
Sep 26, 2009 | Nokia 3220
Nokia e65 proleme
first format ur phone and then write flash
Aug 21, 2009 | Cell Phones
Huh??!!
JAF is the ONLY third party flasher which supports USB flashing. USB flashing is very good and usefull because in case a new phone come out, the user can IMMEDIATELY FLASH THE PHONE, he doesn't need to wait for new F-Bus cable release and to pay expensive delivery costs. The CA-53 cable is included in nearly EVERY BB5 Nokia package.
  • revive dead phones using simple USB cable CA-53 (no need to buy F-Bus cable and to pay expensive delivery costs)
  • BB5 models flashing supported using simple USB cable CA-53
  • the only flasher that can correctly flash Nokia N80 by USB
  • the only flasher that can repair N91 white screen problem
Note that the JAF box does not unlock BB5 phones . It can flash them only!
The JAF box is regarded to be the fastest Nokia Flasher on the market!
No extra power source needed, is powered via USB.
$200.00
Apr 02, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
96 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
