Question about ScanSoft Nuance PaperPort 11 for PC
How to recognize a wireless scanner... I have Paperport 11 running on a system with Windows XP Media Center 2002. I use a wireless Canon MX860 printer/scanner/fax but Paperport will not recognize this scanner. I've checked all the properties and the printer isn't listed.
3 Suggested Answers
SOURCE: I still using ScanSoft PaperPort 11 but my driver
open micromedia
Posted on May 29, 2010
  • 2340 Answers
SOURCE: How di I reinstall PaperPort Print Driver?
Instructions extracted from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
"{Ok, here is how I got the whole package from my Brother MFC and PaperPort 11 with the printer utility.
First if you have tried to install the suite or paperport and are having issues uninstalling through windows download this wonderful program that removes everything called Revo Uninstaller at www.revouninstaller.com and choose the freeware version.
Now go to the Brother website and search for the Windows 7 MFLPRO Suite and you should download a zip file that contains the suite for multiple MFC’s. Unzip it and set it aside. This is only the Brother Suite for the Brother MFC and the Control Center 3.
TO find the Windows 7 version of MFL PRO go here
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=5
PaperPort 11 will have to be installed from the actual CD that came with your printer. Inside the CD with Windows Explorer File System locate the file Inst32.exe that should be inside the CD under the install folder then MFC-465CN (my model) then usa folder. Remember the location.
Now set everything aside and let’s start. Open up control panel, click on programs and features then choose Run programs made for previous versions of Windows. You have just opened up program commutability, now click next and wait now choose not listed and press next. Browse and fine the Inst32.exe file that I mentioned earlier. Now click next and then choose Try Recommended Settings, Next your setting should say applied and compatible with Windows XP SP2, then you will see a tab on the next screen that says Start the program. Click on it and allow it to start installing this will start the suite and the first thing that installs is PaprPort, be patient let it continue to run and after it will install the PaoperPort print driver, then after it will start into the MFL PRO Suite. This is where my installation halted because the suite is a 32Bit version it would not continue. I looked and PaperPort program and printer where installed. Close it up and pres next.
Finally now you can install the MFL PRO for Windows 7. Open up the folder you downloaded from Brother and look for your model and you will see the setup.exe application, click on it and start installing MFL PRO along with Control Center 3. That’s it, and your setup should be complete.}"
Hope the thread from http://social.technet.microsoft.com/Forums/en-US/w7itproappcompat/thread/f903e1ed-e15b-4cb6-a20a-50f628f95939
will help.
Posted on Jul 21, 2010
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Hoe to install canon d646 u ex scanner to window xp
You can download the driver for your scanner from Canon here : http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d646u#DriversAndSoftware Simply select windows XP from the pull down operating system menu, then click 'drivers' and download the driver.
Next, make sure the scanner is unplugged from your system, and run the driver install program, once it is finished, or when prompted by the driver install, plug in your scanner and it should be recognized by the system.
May 29, 2011 | Canon CanoScan D646U Flatbed Scanner
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
How di I reinstall PaperPort Print Driver? PaperPort 11, Windows 7
will help.
Jul 21, 2010 | ScanSoft Nuance PaperPort 11 for PC
I have replaced my xp computer with one running Vista. Will the Visioneer 6600 scanner work with Vista?
The 48-bit color Visioneer OneTouch 6600 USB scanner delivers outstanding image quality by recognizing over 281 trillion colors at 600x1200 dpi optical resolution. The scanner has three convenient buttons that integrate with the ScanSoft PaperPort Deluxe software to make emailing, copying, and storing images and text effortless. The software bundle also includes ScanSoft TextBridge Pro OCR and MGI PhotoSuite III SE.
The scanner driver is certified by Microsoft for Windows XP, and also is compatible with Windows 98, Windows 2000 and Windows Millennium Edition.
It is not compatible with windows Vista.
Apr 25, 2010 | Office Equipment & Supplies
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
It keeps saying that the scanning device is Out of memory/exceeds limits? is this a paperport problem or my scanner? and why all of a sudden? My scanner is a Canon MX860 and has been working great -...
"...till now"
So... what changed? did you install some new software that consumes a lot of resources?
Some update?
Changed something in the resolution? (higher = more memory needed)
check the disk space too, maybe the pagefile is larger than usual.
or, re-install the scanner driver, and PaperPort just to clear things out.
Sep 17, 2009 | ScanSoft PaperPort Deluxe 9...
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Jul 18, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canon Scanner n650u
Try re-installing the drivers , your crash could of corrupted the installed drivers causing your issues. I have installed Media Center on my Father in Law's cpu and found that it is very unstable at times and also many of his installed programs that worked fine under Win XP SP2 either crash frequently or wont work at all. Driver support is an issue for Media Center IMO. I would recommend if you cannot get the scanner to work after you re-install them , think about changing your OS. Good Luck.
Apr 24, 2007 | Canon CanoScan N650U Flatbed Scanner
ScanSoft Nuance  PaperPort 11 for PC Logo
667 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
