Question about Garden
On a CubCadet MTD pto switch,where does the black wire go at the other end?This is a 13A-212F100 model
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
I found a parts diagram for your model, but unfortunately, not a schematic that would show the wiring itself. You may be able to figure it out with some patience. There are two circuits that pass through the switch. One has a lead bringing power (+12V) from the ignition switch, possibly via a fuse; another wire takes this power to the PTO clutch. The second circuit is a safety interlock that kills the engine if you are not in the seat when the PTO clutch is active. It may come from the seat switch and go to a kill relay, but there are variations. Tell more about your trouble symptoms and maybe we can figure it out.
Posted on Aug 02, 2010
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Cub cadet wiring diagrams
the only way is through MTD... or sometimes the owners manual will have it
Aug 18, 2014 | Cub Cadet Model 18611862 Parts Operators...
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
PTO clutch will not engage.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Sep 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
