Question about Frigidaire Affinity ATF7000ES Front Load Washer
WHAT DOES E20 MEANS ON A FRONT LOAD - Frigidaire Affinity ATF7000ES Front Load Washer
  • 4,323 Answers
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then clean the debris from the pump. Make sure that you have a container to collect water nearby when you are removing hoses from the pump, as ther would be a lot of water. Please post back for any further assistance.
Daniel
Posted on Aug 02, 2010
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Tumble action washer keeps giveing me E20
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
Jun 02, 2014 | frigidaire.com
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Error message E20
Hi... error E20 means your washer can't drain you may need a new pump or something is in the pump
Apr 07, 2011 | Frigidaire ATF6000ES Front Load Washer
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
Washing cycle does not complete and I get error E20 with beeps
The E20 error means that the thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
Check the thermistor and associated wiiring for correct resistance and operation and replace if required.
Dec 28, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 72640 update
e20 means cant drain i usually found itsufficient to clean filter and restart but this time i blew down waste pipe /drain,cancelled program and reset
Jan 13, 2008 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
1,048 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
