I have a Samsung Home theater unit that displays the "Protected" message and then shuts down. I have had the unit switched with another one, replaced by Samsung and I still get the same message. Samsung insists it's the unit and wants me to return it for another. I don't think it is since I can unplug all the speakers and and the unit comes on. I then plug one speaker in at a time and turning the unit off and on, on three of the speakers it shows Protected. The speakers are what came in travel trailer that system is installed in, could they be bad or the wrong size, is the wiring grounded out?
  • rauman84341 Aug 02, 2010
    Yes it was thanks for the information I'll give it a shot to see if it works.
  • 10,594 Answers
Yes, it sounds wiring of one speaker got shorted/ grounded some where and causing "protected" message, basically its protection circuit that kicks in when it detects speaker wire shorted out.
Plug one speaker in one time and turn On unit until you find out what speaker kicks protection circuit in. Check that speaker wiring to fix the issue. As you said, unit comes On without speakers that means unit itself is good.
Hope these info will help you.
Thanks.
Posted on Aug 02, 2010
  • 2 more comments
    This unit is in a Fifth Wheel travel trailer. To calrify do you think that the affected speaker is the wrong type, size, or do you believe that there may be a short, broken wrie somewhere along the way?
  • Shahid Electronics
    Shahid Electronics Aug 02, 2010
    I believe speaker wire got shorted because if speaker is wrong size or power, unit will turn off on high volume.
    I havn't ever used it at high volume. The speakers don't sound right. The unit has six speakers the front ones normally appear to be working correctly. If I unplug them and then plug in one of the back speakers they don't sound write but there is sound coming out of them. In this condition they do not trip the protected message. But if all are plugged in then they do.
    6 speakers system is actually surround sound system and all speakers wont give sound at same time. It depends on sound track that is recorded long with video that you hear sound may be few speakers to get surround sound effect.
    Front speakers are called main speakers that usually give more sound other than surround/ rear speakers. There would be one center speaker for vocal/ dialogue sound of movie and rest of speakers will give sound as per scene requirements.
    Try one speaker at one time and turn unit on to identify what speaker wire is causing problem. Unplug only that speaker and plug rest of speaker and play the unit.
    Check defective speaker wiring to fix the problem.
    Thanks.
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
Samsung Digital Home Theater System keeps shutting down not even a full minute after turning it on. What's the problem?
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jul 04, 2009 | Samsung Audio Players & Recorders
Fan chk problem too
Jul 04, 2009 | Samsung HT-Z310T Theater System
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
Jun 29, 2009 | Samsung HT-Z310T Theater System
Once switched on, PROTECT appears on screeen and system turns off
Jun 29, 2009 | Samsung HT-DS1000 System
Hello Protection Samsung HT-DS900
Jun 14, 2009 | Samsung HT-DS400 System
Can't get the disc drawer to open/ close
Hope this helps!
Jun 13, 2009 | Samsung HT-Q70 Home Theater System System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
59 people viewed this question
 Grubhead
Grubhead
