Question about Fuji FinePix S2000hd Digital Camera
Pictures are on internal memory card. How do I transfer them to an SD card to print
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Press Playback (the right-pointing triangle) to enter Playback mode. Press MENU/OK to display the Playback menu. Use up/down to highlight "COPY" and press right to select it.
For full details, see the section "COPY" under "Using the Menus: Playback Mode" in the manual.
Posted on Aug 02, 2010
Testimonial: "Thank you so much for your prompt and precise response. It worked perfectly. Have a great day!"
How do I transfer pictures from the internal storage to a sd card?
hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card? Follow these steps:
  1. Insert a memory card into your camera.
  2. Turn on your camera.
  3. On the camera, press the Review button then the Menu button.
  4. On the Setup tab in the menu (your menu tabs might be named differently), select Image Storage.
  5. Select Internal Memory.
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
Nov 05, 2017 | Cameras
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
How do I take the pictures out of the internal memory and put them on an SD card so I can take them OUT of the internal camera memory?
Use the "Copy" command in the Playback menu to copy the pictures from the internal memory to the card. Once the pictures have been safely transferred to your computer, format the internal memory to clear it.
Jun 19, 2012 | Nikon Coolpix S6100 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
I took picture w/o SD card. Don't know how to transfer to SD
Search the menus for an entry for "copy". It should give you the option to copy the internal memory to a memory card. You could also take the camera and a usb connecting cord to a store like Walmart that has a Kodak picture maker machine. You can plug the camera into the usb slot and print the picture.
Sep 11, 2009 | Samsung Digimax S730 Digital Camera
Fuji FinePix S2000hd Digital Camera Logo
345 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
