Question about KitchenAid 34 in. KUDP01FLSS Stainless Steel Built-in Dishwasher
My kitchenaid kuds24se won't run or drain (it filled and stopped). If I remove the drain hose to clear it while the tub is full of water, will the water run out all over the floor?
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
SOURCE: Kitchenaid dishwaser poor cleaning KUDS24SE
There are 2 likely candidates. The first is the chopper - the device that grinds up the food. The second is the check valve - a rubber flapper that sets to the right of the chopper. Over time it becomes stuck open which reduces pressure at the spray arms.
Good luck - I had the same issue on my KUDR01J.
Posted on Dec 17, 2008
  • 244 Answers
SOURCE: Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Posted on Feb 16, 2009
  • 457 Answers
SOURCE: water will not completly drain from bottom of tub.
drain pump clogged . remove obstruction
Posted on Feb 25, 2010
tbirdfan1
  • 3051 Answers
SOURCE: my kitchenAid dishwasher won't drain well. the
Hello there again I am really sorry we got disconnected
Please try this
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Posted on Jun 27, 2010
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Water keeps filling but will not start cycle.
The top load washer utilizes a pressure switch attached to a clear plastic hose. If the water fills the tub but will not stop filling you will need to remove the top panel and inspect the hose for obstructions. You may need to disconnect the tube flush it clean and make sure no foreign debris are in the connector on the pressure switch. If the tub will over fill, you may need to replace the pressure switch. If the water will not fill the tub and the water continues to run you need to check the drain pump. Is water exiting through the drain hose? If so the drain pump could be the problem.
Feb 23, 2011 | Washing Machines
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Stops during rinse cycle and water will not empty out of tub. ? switch to pump??? Now I have a tub full of dirty water that won't drain
Model may vary, but this could be helpful for sure.
1. Unplug machine. Drain out maximum water by lowering the drain pipe into bucket or lower drain.
2. Remove the lower kick plate under the door. There will be a screws in the bottom corners of the panel holding it on.
3. Find the drain pump. It will be on the right-hand side and is
usually white in color. The drain hose from the bottom of the tub
will be connected to it.
4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it.
5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere.
6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught.
7. Clean out the pump and drain hoses. Located in the hose coming down from the tub is the filter, check this out for cleaning.
8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "cancel" button to stop. Make sure you place the drain hose back in the standpipe too.
Mar 19, 2009 | Kenmore Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
Does not drain
take the front cover off and have a bucket and towels ready ,, remove the hose clamp off the drain line and remove it slowly to keep up with the water that will seep out of the line after it stops draining run water theu the drain and flush the system the take the hose off and run water thru it ,, out side,, then check if it goes into an air gap clear both sides of the air gap and all hoses,, if after doing all of this and it still won't drain, you will need to change the pump
Feb 26, 2008 | Hotpoint 24 in. HDA3400G Built-in...
KitchenAid 34 in. KUDP01FLSS Stainless Steel Built-in Dishwasher Logo
187 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
