When i turn my game console and press the power button unil it beeps 2 times. this brings up 5 options, when i try to rebate the software on option number it displays that 'your hard disk can not be accessed. After this i try to restore the data it displays that 'you have a serious error and error code 80001002b. i have also tried to swap the hard disk with another ps3 but this does not make any difference. what does this mean and how can i fix it? Thankyou
SOURCE: No HDD Found on initial XP Install
Make floppy for SATA, when start instlling Windowz press F6 and this is it!
Posted on Mar 12, 2007
debbily
  • 101 Answers
SOURCE: pc-chip m957g
sounds like the motherboard has failed. I had those same symptoms this summer. Replaced m/b and it's good again.  Did you count the 'continuous' beeps? That's a code to say what is wrong.
Posted on Oct 14, 2007
Philster
  • 113 Answers
SOURCE: FIC P4M 915G/PD1 system fails to Power Up
You should always try a new power supply if possible. After all, it is one of the most likely components to fail - it's got moving parts (one or more fans), just like your hard drive (spinning platters), one of the other most likely parts to die.
That said, in this instance it probably is the mobo. FIC made great motherboards, but they got out of the business so you won't find the same one anywhere. If you have to replace it, you may be able to get out of a Windows reinstall by getting a motherboard with the same chipset, which looks like a 915/G, though any 915 based board might do. You may still need to do a repair install, but in many cases the same chipset allows you to boot and then just load all the new different drivers for the new board.
Posted on Jan 27, 2008
frcs68
  • 1605 Answers
SOURCE: Computer will not boot up.
remove all external devices. except the memories.
turn on the PC.
it if comes on insert each of the external device one at a time, till you come across the one that is causing the problem.
if it doesn't come on, remove the memories. and swap the memories. if it still doesn't come on, remove the memories. and see if the BIOS come sup. if it doesn't, then you have motherboard problem.
go back and check all connections. make sure the connectors are in right orientation and not pins are missing.
Posted on Nov 03, 2008
  • 135 Answers
SOURCE: sony vaio laptop model no VGN-S170P dose'nt boot / power up
Hardware problem, definitely!
Cooling fan intermittent and overheating RAM and Video Chip (and processor).
After verifying fan is running, boot with ubuntu live cd and run memcheck.
Posted on Feb 16, 2009
My Ps3 wont load the dashboard help
Please try the following solution to fix your PS3. Please note, option 5 will erase your hard drive so any save games you had will be lost.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. If it still does not work try the above but choose option 4. If that does not work try option 5 as a last resort, this will erase the hard drive.
Once you have completed the above, the Playstation 3 should restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
When i power on the ps3 it dosnt go past the first 'wavey' screen n dose not go to my home screen just stays on the 'wavey' screen
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, using option 5 will erase your hard drive so any save games you had will be lost. All your on-line trophies will be preserved.
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
The Playstation 3 will now go through the system restore process and re-install the system software. Once you have completed the above, the Playstation 3 should restart and spring back to life again. If it does not, do the above but choose option 4. If this does not work do the above again and choose option 5. Option 5 will format your hard drive.
I hope this helps and thank you for using FixYa
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped showin the icons but its loading up the front screen is there but no icons ?
Your software needs re-installing, follow this procedure :
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and switch off back into standby mode (red light on)
Step 3. Press and hold the power button again. It will beep when you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. A menu will load up with 6 options. Choose option 3 first "Restore File System" and go through this process. If this does not work do the above but choose option 4, then as a last resort option 5. A warning though, option 5 will erase all your data on the hard drive.
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't get to the main menu when I turn it on
Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
When you have done all this your PS3 should be fully working again.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
Got a playstation 3 ,you turn it on and doesnt load to the main screen only comes up with ps3 and then the wavy lines can u help
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 3 system that worked for 1 day & the next time i attempted to play it,it did nt go past the initial playstation intro screen.The screen is grey with the playstation wave symbol...
Ok, follow these steps to cure your problem. Warning, you will lose saved game data!!
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you press it, then beep 5 seconds later and then once more another 5 seconds later and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep once when you press it, again 5 seconds later and then 2 quick beeps together. When you hear these 2 beeps release the power button
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. The options menu will display. Select option 5 "Restore PS3 System". The PS3 will re-install the software required and restart. Hopefully this will solve your problem
Hope this helps and thank you for using FixYa.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Corrupt hardhrive msg comes up and can not do anything
Follow these steps to try and bring your hard drive back to life :-
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off please let go of the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps let go of the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
