Question about Novatel Computers & Internet
Upgraded desktop pc from Win 2000 pro to WinXP Pro w/SP3. purchased novatel modem from Wal-Mart to connect to Virgin Mobile. Auto installer runs successfully when first inserting device into USB port. however, after rebooting pc, only the memory feature of modem is recognized, modem is not. when software runs, dialog box says no device is connected when it is. i have uninstalled and re-installed device several times and get the same result. virgin mobile help desk is no use. anybody know what the problem is?
    Top Expert:
  • Novatel Master
  • 51,280 Answers
Try downloading the drivers for the modem
Posted on May 19, 2017
5 Suggested Answers
  • 5 Answers
SOURCE: memory stick pro duo pc connection
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Posted on Feb 11, 2008
  • 4 Answers
SOURCE: Cannot connect using LG internet cube software
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
Posted on May 12, 2008
  • 10 Answers
SOURCE: Epivalley SEC-8089 USB CDMA Modem from Tata Indicom- No Support.
you are in user mode dear log into admin mode and have all rights
Posted on Sep 13, 2009
  • 4090 Answers
SOURCE: I have an unlocked bigpond modem ,and I am trying to
once you get the setup disk from virgin and you put your sim into the Bigpond modem, gollow the Virgin prompts it should work once you have searched the right network parameters and entered the IMEI code etc. It takes about 24 hours for virgin to switch you online.
Thanks for using FIXYA
Posted on Nov 24, 2009
Virgin broadband I have a locked Overdrive Pro C54 modem and cannot get it unlocked. I have a Samsung tablet and it will not pick up a signal from my hotspot.
By unlocked, if you mean you can not access the WEP or WPA code and wish to edit it it, the default user id and password for most routers is admin and admin or admin and password.
May 24, 2014 | Novatel MiFi 2200 Mobile WiFi Hotspot...
HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
Aug 24, 2012 | HP Computers & Internet
CAN NOT FIND THE DRIVERS FOR MY MC760 USB MODEM
From what I found the drivers from Virgin Mobile do not always work.
This link is for an original Novatel Ovation MC760-Virgin Mobile Broadband2Go install package on Google Docs kindly provided by Headworx:\
https://docs.google.com/uc?export=download&confirm=no_antivirus&id=0B9nmw2Nv8RaaYWFhMmU4YjEtOGE5Zi00NjIzLWJhNjctNzI4ZTk5NTFhYzc2
Remove the USB modem. Uninstall all things Virgin Mobile and Novatel, programs and in the Device control panel; run LiteAuto.exe from the zip file; then plug the USB modem back in. Driver package will auto install.
Let me know if you need anything else!
Jun 29, 2011 | Computers & Internet
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Well if you have it installed on the computer and cant get past the Windows logo. Put the SP3 disk in and do a repair. Make sure you hit -R and not the repair button after clicking continue. Well the directions for a repair will be on the screen. That is my thoughts on what you should do. If you have already done this, then I'm not sure where you should head to next. Hope this helps!!
Mar 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Video driver doesnt work after new WinXP install- system locks up
it will lock up if you not using the correct driver try downloading a driver version that support sp3 go to thier website and browse for a driver the will work with sp3
Nov 22, 2009 | Sony VAIO PCV-W20 PC Desktop
Cannot connect my MT6225 china phone to my laptop thro the USB. what can i do?
hello, u may have to download the proper drivers plus data manager software from the manufacturers homepage,
they have to fit vista!
if there are just ones for winxp or lower win/versions available, either try connecting phone to a winxp/interent-pc and go through driver-install and so on
or think about downgrading your system to win-xp professional!
win vista is fine but not as reliable as winxp/pro!
good luck
Aug 07, 2009 | Microsoft Windows? Vista Home Premium...
In new winxp pro sp3 installation ethernet dosen't work
Are you trying to install SP3 via the Internet?
This file is approx 350 Mb in size, suggest you get a copy on CD from a computer savy friend or your friendly computer shop or purchase from Microsoft.
May 09, 2009 | Computers & Internet
Uninstall WIN XP PRO UPGRADE
Unfortunately you cannot "Uninstall an Upgrade" - Do you refer "Upgrade to SP2/ SP3 or WIN98 or WIN2000 to WIN XP? Please clarify? Regardless - you will have to reformat your PC and purchase a new license key as you have used the one on another PC or you should void the license on that PC and use it on the original PC.
In short unless you do not use the license key or purchase a new one, your PC will not log-in after 30 days and you will then have to activate again using telephonic assitance (if you modem and internet connection were no configured before the end of you activation period. There is now Un-install function. Sorry.
Apr 17, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Top Novatel Computers & Internet Experts
ray gallant
Chris
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
