Question about Roper Dryers
My dryer gets hot but is not drying the clothes. It takes 2 to 3 cycles.
    President:
  • 3,773 Answers
Chec that dryer is not pushed back against the vent crimping it.
Check blower air velocity where it vents outside.
Wash Filter with dishwashing liquid and brush.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 02, 2010
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
My dryer will heat up, but it is not drying the clothes during the cycle. It takes 2 or 2.5 cycles to dry the load
if you have the top model lint filter take it out put your hand in and see if you have good air sucken,if not you have a clogg somewhere in the dryer hose or wall vent,most of the time it is the wall vent, if the hot wet air can't get out the cloths will take forever to dry-mike
Feb 06, 2010 | Kenmore Dryers
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
