Question about Whirlpool Microwave Ovens
Whirlpool AMW 575 microwave door handle came loose how do i get to the screws to re-secure
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: How to replace cracked plastic door frame on Whirlpool microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Replacing a whirlpool microwave door handle! got
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 25, 2009
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Replacing a handle on a kitchenaide microwave
Hello
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Microwave Ovens
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
from the door frame.
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Replacing a whirlpool microwave door handle! got the new handle..how do I open the door up to screw the new handle on?
Nov 24, 2009 | Whirlpool MH7140XF Microwave Oven
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
Whirlpool mh7130xez-1
When you open the microwave door, on the inside of the door there is a plastic trim around the glass called a choke that is clipped in that needs to be removed to get to the screws for your handle
Oct 29, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
